    Aug 2009
    Default Updated underwater transom lighting
    Added the 2 additional lights on the weekend, so here's what I've got so far.
    IMG_0395.jpg; Boat pic 4.jpg; Boat pic 5.jpg; Boat pic 6.jpg; Boat pic 3.jpg
    The 2 additional lights are still below the water line, and punching the whole through the transom was still contained within the storage compartment, just above the ballast bag feed lines.
    Was then able to tie the wiring to the back side of the ballast bag feed lines to keep them out of sight for other than a small wire coming through inside.
    This was the flatest surface that existed on the transom in order to maximize straight out light dispersion. The are just slightly off 90 degrees hence why they are not as straight as the centre.
    Then tied into the existing wiring that was in place for the first light, and "voila" (that's french).
    Thought about other locations, but the centre light is already quite bright so wanted to create a larger area of light.
    Night pictures forthcoming after July long weekend.
    Until then...
    Lumitech SeaBlaze 3
    Amphibian Pro A6
    Jul 2009
    Granbury TX
    Looks awesome, should light up the wave nicely if you want to do some night surfing.
    -2012 Supra 21v
    -2008 Mobius LSV
    Nice looking leds never noticed the mobvone on the back.
    Mar 2012
    NJ
    this install I really like. Those two oval looking likes on the port and starboard side of the transom are very nice. much better profile than something else I've seen. I'm interested to see your night pictures, bet it looks great. Have any pictures of the actual holes you drilled for each light?
    Justin
    2008 Supra 21V
    2008 Supra 21V
    1,450 lbs., Gravity III ballast system
    Z5 Cargo Rack
    Stereo: Pair of Wetsounds Pro 80's, Rockford Fosgate P500-2, Kicker ZX200.4, Exile ZLD, stock Kicker in-cabins, stock Kenwood HU
    Tow rig: 2008 Slate Tundra, Bilstein 5100's (F&R)
    Aug 2009
    It's just a 3/8 hole like the manufacturer recommends. Sorry no picture of it. Very simple install.
    Hopefully night pictures coming in 2 weeks.
    Irondequoit Bay, NY
    were you crying when you drilled some holes into the back of your boat? or were you slightly intox and said " F*#& IT, lets do this" haha
    Rockford fasgate cabins
    Rockford fasgate 500w amp (cabin) and a sony cd/ipod player
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Aug 2009
    All of the above.
    It's like beating your child. Sometimes it needs to be done, but you hate to do it...(that was humour)
