Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Aug 2006
    Default Fat sac glue question?
    What do you use to glue them in??
    I'm sure it's been addressed 29 times already.
    Thanks.
    Time for a surf sac
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Do you mean the fittings? I didn't glue mine in at all, just tighten them up. Knock on wood, no leaks.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Aug 2006
    Yes, fittings.. Thks for reading my mind
    Brad
    2011 Launch 21V
    2004 Outback sold
    I've used just some pipe tape. Others suggest the pipe dope stuff or the pvc cement. If you ever want to get them out you might think about how permanent you want it. It's low pressure so I don't see why you need anything but the pipe tape works great.
    Wakemakers recommended all purpose pvc cement. I have a port that is leaking enough that thread tape won't fix it so I'm planning to give this a try.
    Just hand tighten, leave glue for last resort, Teflon tape is 2nd step.
    Aug 2006
    Went with tape. Wasn't up for the glue. We'll see how it holds
    Brad
    2011 Launch 21V
    2004 Outback sold
    Aug 2010
    Acworth, GA
    I think taco beat would weld them in... but that's just a guess
    Kraig - 2010 Outback V
    Jul 2011
    Murrieta, CA
    I tried both methods. Only the PVC glue held for me. The downside is that the fittings may be permanent. But - no more fittings popping out and sending 400 lbs of water onto the carpet and into the bilge.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Muskoka, Ontario
    I dont see how the fitting could pop out. When I installed mine on the 750's it was a real stretch to get them in all the way.
    On another note I want to take them off on the OEM 400 bags. Does heat help? They are on there good, not sure if Moomba puts glue on them from the factory.
