Heat from a hair dryer for 10-15 min, then pop them out. Wakemakers has a great video on their site.
Results 11 to 19 of 19
Thread: Fat sac glue question?
06-25-2012, 10:26 PM #11
New ride: 2012 Mojo
Old ride: 2008 OBV
06-25-2012, 10:50 PM #12
My bags were not glued from the factory. I think the heat from the engine was heating the fitting on the v drive bags and they would pop out to the bags after an hour or so on the water.
Then I glued them and have had no problems since.2010 Moomba XLV
340hp cat
Gravity 3, wake plate
Rad-a-cage
1100 surf side v-locker
650 in the floor locker
600 to move around
06-26-2012, 09:10 AM #13
Senior Member
- May 2010
- Muskoka, Ontario
- 363
06-26-2012, 09:41 AM #14
The plastic threaded adapter was popping out from the bag's threaded insert. After a couple of times the threads were marred a bit and seemed to pop even more often.
A small amount of PVC cement and the fittings have never popped out again.2010 Moomba XLV
340hp cat
Rad-a-cage
600 to move around
06-26-2012, 09:44 AM #15
Senior Member
- May 2010
- Muskoka, Ontario
- 363
I wonder if its a design flaw on Fly Highs part, since a threaded coupling should never be able to pop straight out, unscrew is a different issue.
06-26-2012, 09:53 AM #16
you actually "pop" out the ones that are glued in from the factory ofter you heat them up a bit with a hair dryer.
New ride: 2012 Mojo
Old ride: 2008 OBV
06-26-2012, 10:44 AM #17
Senior Member
- May 2010
- Muskoka, Ontario
- 363
Hmmm one would think that would ruin the threads on the bags? No?
06-26-2012, 12:57 PM #18
only when one makes the mistake of using a heat gun instead of a hair dryer and leaves it pointed at the bag until their daughter asks, "Is it supposed to be smoking?"
BTW - I have a factory bag for sale. CHEAP!Drew
New ride: 2012 Mojo
Old ride: 2008 OBV
06-26-2012, 11:26 PM #19
