Results 11 to 19 of 19
    Heat from a hair dryer for 10-15 min, then pop them out. Wakemakers has a great video on their site.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Jul 2011
    Oregon City, OR
    My bags were not glued from the factory. I think the heat from the engine was heating the fitting on the v drive bags and they would pop out to the bags after an hour or so on the water.
    Then I glued them and have had no problems since.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 surf side v-locker
    650 in the floor locker
    600 to move around
    Muskoka, Ontario
    Are you talking about the threaded adapter popping out from the bag or the quick release fitting from Fly High with the little red clips?
    Jul 2011
    Oregon City, OR
    The plastic threaded adapter was popping out from the bag's threaded insert. After a couple of times the threads were marred a bit and seemed to pop even more often.
    A small amount of PVC cement and the fittings have never popped out again.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
    600 to move around
    Muskoka, Ontario
    I wonder if its a design flaw on Fly Highs part, since a threaded coupling should never be able to pop straight out, unscrew is a different issue.
    you actually "pop" out the ones that are glued in from the factory ofter you heat them up a bit with a hair dryer.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Muskoka, Ontario
    Hmmm one would think that would ruin the threads on the bags? No?
    only when one makes the mistake of using a heat gun instead of a hair dryer and leaves it pointed at the bag until their daughter asks, "Is it supposed to be smoking?"
    BTW - I have a factory bag for sale. CHEAP!
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Quote Originally Posted by loudsubz View Post
    Nope threads are fine if the directions are followed
