Results 1 to 2 of 2
    Default Transmission Mount Bushing Replacement
    Here is a short video on replacing the transmission mount bushing.
    Tools 15/16"- 1" wrench, 2- 9/16 wrenches for alignment, come along with chains,feeler gauge, 1-2 beers
    I noticed my rubber bushing had mushroomed so I purchased some new mounts from inboardonline.com for a cost of $8.61 each so I would have spares. Only needed one as I believe alot of the weight was being taken on the other mount. The culprit was a raised edge on the casting that trashed the rubber bushing. Checking of these mounts should be added to the summerization process.
    Here is the video link.
    . http://www.youtube.com/watch?v=qwc7iy5T3Ic
    Jun 2009
    South West Colorado
    Any insight into what the bushing part number is that you replaced? The inboard online website is not working so I can't see what options there are. Also what extra parts might I need besides the top bushing? I have an 08 lsv.
    Thanks in advance for any help.
