Hey guys, I have a 2004 Moomba Mobius LSV and am looking for some recommendations for fat sacs and the type of perfect pass to install. Any suggestions are greatly appreciated and I thank you guys in
advance for all your help.
I am looking to install a Perfect Pass system in my Moomba for the most part to just wakeboard and
wakesurf. I was looking at the Perfect Pass systems but they have a lot of different types and did not
know which one worked best with the Moomba's and which one was most consistent keeping a constant
speed and the one that worked best in turns.
Also, I am looking to purchase some fat sacs for each of the compartments on each side of the engine and
and one for the open bow of the boat. Again, these would be used for both wakeboarding and
wakesurfing. If you guys have any recommendations with the sizes you have used or are using now I
really appreciate it. I have ballast in my center ski locker but do not know how many lbs it is... does
anyone know how many lbs this center ski locker ballast is?
Thanks a lot guys, I really appreciate all your help.
Mike
Results 1 to 10 of 12
07-21-2012, 11:23 AM #1
Junior Member
- Jun 2012
- 7
Fat Sac recommendation and Perfect Pass
07-21-2012, 12:06 PM #2
i dont know anything about the PP but head over to wakemakers.com and they have all the sacs you need for the mobius..thats where i picked up my parts for my sacs
Rockford fasgate cabins
Rockford fasgate 500w amp (cabin) and a sony cd/ipod player
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
Polk P330 amp (subs)
07-21-2012, 02:07 PM #3
Senior Member
- Aug 2011
- 366
Wait a few months and pickup some used 750's...I bought 3....For perfect pass, depends on where you use it, on lakes the gps stargazer one, if on a river the older paddle wheel style, if you have any bridges or anything that blocks the gps signal get the older style, the stargazer gps one goes nuts everytime we pass under a bridge...
2002 Moomba Mobius LSV
07-21-2012, 02:10 PM #4
Parrot is right on. Run 750's in the side compartments and the ibs in the front. Did you get the boat with the g III setup or are you starting fresh?
2005 mobius lsv 2900lbs ballast2005 mobius lsv
07-21-2012, 02:58 PM #5
I found the 750's to be to narrow to fill my compartments. The 1100's are 4" wider and fit perfect. They are the same length as the 750's. They are 4" taller, doesn't bother me any. My bow sac is a perfect fit. Wakemakers can help you no matter what sacs/pumps you pic. They are very busy right now but are returning calls and emails the next business day.
-Jake
07-21-2012, 07:37 PM #6
Junior Member
- Jun 2012
- 7
Thanks for all your replies. I'm starting fresh. Just got my Moomba this year so just trying to figure out what works best. The boat is out on a lake with not bridges so should have good clear signal to satellite for the GPS for the Perfect Pass. Seems like I could go with the 750's for the compartments. The Compartments should have no problem supporting this ammount of weight right? And Would I need anything for the bow to bring the boat back down on plane or will the center locker ballast take care of this?
07-21-2012, 09:46 PM #7
Senior Member
- Aug 2011
- 366
07-21-2012, 11:24 PM #8
Don't know that you need it, but you will really like having it. Just have to be a bit more careful that you don't take too many rollers over the bow.
Drew
New ride: 2012 Mojo
Old ride: 2008 OBV
07-23-2012, 05:44 PM #9
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
07-23-2012, 06:45 PM #10
Hey MoombaMike - there are a few active members on here with earlier LSV's you could hit up. NewGuy is one I can think of off the top. Good advice given already. 750's do great, not everyone thinks you need to go 1100's but if you are starting from scratch they really aren't that much more $ and will "mostly" fit the compartments. Not sure what your rear compartment walls look like but you may want to consider reinforcing them if you go big.
I think the best advice starting from scratch on the rear ballast is that if you think you'll go big some day, just go big from day one and save yourself the time and money later on.
Weight in the bow is always something you can experiment with cheaper/loaner bags on the seats before committing to an IBS too.
I'm a fan of Stargazer PP personally and I run on both lakes and rivers - I also was starting from scratch and after talking to the guys at PP they convinced me to go the Stargazer route. Have to adjust speed sometimes for the river current but not a big deal. Haven't had an issue with GPS signal yet. Paddle wheel works fine - you'll just have to drill another hole in the bottom of the boat for it and I understand it needs to be re-calibrated every few seasons.2001 MobiusV
