Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 59
    Jul 2011
    SE MI
    I think Autozone Advanced etc will test your starter for free...
    Tampa, FL
    The gap on the plugs (.45) is correct. No worries there.
    There is a link on this website at the top under "Community" and then "Downloads" for a boat manual for your boat.
    If you check your phone book, you should be able to find a starter/alternator repair store in your area. If you can get the starter off (2 bolts at the bottom of the starter), you can take it to them for a test. Usually, they can repair or replace it for less than a starter from a marine store/dealer. Having it repaired means that you will have no shimming issues that you might have by getting another (new) starter.
    2008 Outback
    +1, I'd stay away from autozone, they can test the starter works, but can't test the bendix...
    2002 Moomba Mobius LSV
    I'd use it as an excuse to buy a 2013 LSV.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    OH
    i'd use it as an excuse to buy a 2013 lsv.
    man i wish!!!
    1998 Outback
    Irondequoit Bay, NY
    second..maybe i sould sink mine and get a 13 haha i kid i kid
    Rockford fasgate cabins
    Rockford fasgate 500w amp (cabin) and a sony cd/ipod player
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    OH
    Well, took the starter out last night and took it to advanced (I know a couple said not to but there is nowhere else around here to take it) they did their test and it failed!! thanks for the help all, hopefully this will do the trick! going to call a place nearby and see about having it rebuilt. Again thanks a ton!
    Brian
    1998 Outback
    OH
    ***UPDATE***
    Had the starter replaced put it back on last night and tired it out..........NOTHING, same thing. I have ordered a distributor cap and rotor because mine is a bit corroded and am going to change out the fuel filter....any other suggestions??
    thanks
    1998 Outback
    Deep River Ont
    It's still your starter!!! Is it a new starter? I cant access youtube from work but I have heard the noise a starter makes when it's not popping out and engaging the engine and judging by the reaction others have had to the noise its making, that is what is happening!! Did you re-install the starter?
    2008 xlv gg 340hp
    Quote Originally Posted by myster View Post
    Guess I'm confused what is the issue?
    Does the engine not start and run or just the starter not engaging?
