I think Autozone Advanced etc will test your starter for free...
Results 11 to 20 of 59
07-25-2012, 01:41 PM #11
07-25-2012, 01:43 PM #12
Senior Member
- Jan 2008
- Tampa, FL
- 1,361
The gap on the plugs (.45) is correct. No worries there.
There is a link on this website at the top under "Community" and then "Downloads" for a boat manual for your boat.
If you check your phone book, you should be able to find a starter/alternator repair store in your area. If you can get the starter off (2 bolts at the bottom of the starter), you can take it to them for a test. Usually, they can repair or replace it for less than a starter from a marine store/dealer. Having it repaired means that you will have no shimming issues that you might have by getting another (new) starter.2008 Outback
07-25-2012, 03:23 PM #13
Senior Member
- Aug 2011
- 372
07-25-2012, 03:29 PM #14
I'd use it as an excuse to buy a 2013 LSV.
Drew
New ride: 2012 Mojo
Old ride: 2008 OBV
07-25-2012, 04:34 PM #15
Member
- Jun 2012
- OH
- 74
07-25-2012, 07:25 PM #16
Rockford fasgate cabins
Rockford fasgate 500w amp (cabin) and a sony cd/ipod player
Exile XM7's
Exile Harpoon
Exile ZLD
Polk 10in sub (2)
Polk P330 amp (subs)
07-26-2012, 08:42 AM #17
Member
- Jun 2012
- OH
- 74
Well, took the starter out last night and took it to advanced (I know a couple said not to but there is nowhere else around here to take it) they did their test and it failed!! thanks for the help all, hopefully this will do the trick! going to call a place nearby and see about having it rebuilt. Again thanks a ton!
Brian1998 Outback
07-31-2012, 09:45 AM #18
Member
- Jun 2012
- OH
- 74
***UPDATE***
Had the starter replaced put it back on last night and tired it out..........NOTHING, same thing. I have ordered a distributor cap and rotor because mine is a bit corroded and am going to change out the fuel filter....any other suggestions??
thanks1998 Outback
07-31-2012, 09:53 AM #19
Member
- Jul 2010
- Deep River Ont
- 77
It's still your starter!!! Is it a new starter? I cant access youtube from work but I have heard the noise a starter makes when it's not popping out and engaging the engine and judging by the reaction others have had to the noise its making, that is what is happening!! Did you re-install the starter?
2008 xlv gg 340hp
07-31-2012, 10:01 AM #20
Senior Member
- Aug 2011
- 372
