Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
  1. #51
    Portland Oregon
    Never used my blower on in 10 years either, but what do I know.
    -Jake
  2. #52
    Aug 2011
    Crank the engine with the dizzy cap off. Does the rotor turn? If not, then the starter isn't cranking the engine. Simple check.
    2004 Moomba Mobius LS
  3. #53
    Jul 2012
    Southeast Michigan
    It is 100% the starter not engaging.
    Perhaps not enough current being supplied to the starter to make the gear pop out and engage the flywheel.
    2007 Moomba Mobius LSV "wrapped"
  4. #54
    OH
    Quote Originally Posted by kanakry View Post
    not enough current like charge the battery up or wiring problem?
    1998 Outback
  5. #55
    Sep 2009
    newnan, GA
    Get another starter. End of story
    2005 mobius lsv 2900lbs ballast
    2005 mobius lsv
  6. #56
    OH
    Quote Originally Posted by ga-lsv05 View Post
    yup thats happening today or tom that way i can either be on the water or ruling it out
    1998 Outback
  7. #57
    OH
    FIXED!!!! it was the key ignition. I went to advanced and got one earlier and now were running. I thought that it just didn't feel right, hard to put the key in and weird turning it to start the motor. I thought "hey its only $10" and BAMM!
    Thanks for the help everyone, I didn't spend a ton of money and i sure learned a lot!!!
    1998 Outback
  8. #58
    May 2007
    Richmond, VA and Deerfield, IL
    Quote Originally Posted by BGeorge01 View Post
    Good work. Now, be sure to run the blower -- every time -- before starting the engine.
    2007 Outback
    2012 RAM Crew Cab
    Stuart
  9. #59
    Sep 2009
    newnan, GA
    Don't want to rain on your parade but, the ignition switch only has 1 wire that goes to a relay that's either powered or off. Highly unlikely that this fixed your issue. But I hope it did. I would certainly keep my fingers crossed in hopes that your starter holds up
    2005 mobius lsv
