    Oct 2010
    Winnipeg, Manitoba
    Default fixing axle leak
    There was a bad leak on the inner seal of the right hub, so I decided to get to it. I got the serial number off the axle and went on to the ufp website and sent them an email asking which bearings and seals I needed. I gave them the axle serial number and they sent me all the numbers along with links to maintaining the axle. So before I took anything apart I went and bought all the parts. Got everything apart and got ready for reassembly and found a problem.
    Put the new bearings up against the new ones.
    Oops. I think there's something wrong.
    Of course the number is worn off the outer bearing, but as luck would have it I could see the number in the race. They're both the same. Time for a trip back to the bearing supply store.
    Luckily, a friend has a boatmate trailer one year newer than mine and he hardly uses it. I switched trailers before I started all this work. Sure looks weird a blue boat on a red trailer.
    Been a long time since I got my hands greasy. Forgot what it's like.
    past---------------2003 Outback SOLD
    present------------2006 Supra Launch 21
    possible future-----2013 Mojo
    Ron
    Oct 2010
    Winnipeg, Manitoba
    Forgot. For the record, I'm thinking of ways to incorporate my Christmas lights into the hub, but I've got to find some long life brushes cause the hub keeps spinning. Hope you're happy Drew....
    Ron
    Heck, I was happy to read of the red and blue color combo. I figure you throw in a little white and you'd be living right!
    Drew
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Oct 2010
    Winnipeg, Manitoba
    Actually the boat is blue AND white. So I guess I am living right.
    Ron
    Jun 2010
    Lake Houston
    Quote Originally Posted by rsinger View Post
    Get some bearings that have a tigher inner race tolerance. C3 fit or better. Heat them up and then slide on the shaft.
    2013 LSV
