Ok. I have a 2002 Outback LS carb engine. Last week boat started to die out on water. Kept acting like I was out of gas. Finally got it on the trailer, aand brought it home. Changed the fuel filter and just triued to take it back out. Cranks but no fire. Oil pressure is showing on the gauge when I crank. I am thinking bad fuel pump, but not sure how to test it.
Results 1 to 10 of 44
Thread: boat cranks but wont start
09-03-2012, 10:52 AM #1
Member
- May 2008
- Howell, Mi
- 57
02 Outback LS
Howell, Mi
09-03-2012, 11:11 AM #2
Member
- May 2008
- Howell, Mi
- 57
I just ran jumper wires directly from battery to pump. and hummed for a few seconds then gurgled and quit. Now it doesn't do anything when I jump it.
Frustrating...Doug
02 Outback LS
Howell, Mi
09-03-2012, 11:55 AM #3
Senior Member
- Jun 2010
- Lake Houston
- 615
Does the boat get taken out very regularly?
2013 LSV
09-03-2012, 12:01 PM #4
Member
- May 2008
- Howell, Mi
- 57
yes, every weekend.
I just jumped across the 2 wires at the oil pressure sensor and still no start.
I dumped a little gas down card and get it run for a second. Really thinking my fuel pump is shot. Trying to find one right now.
What were you thinking?Doug
02 Outback LS
Howell, Mi
09-03-2012, 12:05 PM #5
Senior Member
- Jun 2010
- Lake Houston
- 615
Either the fuel pump or filter but the pilot jets get clogged in motors so easy these days. If you put it in neutral and give it half throttle will it start? That'll tell you right away what the problem is.
2013 LSV
09-03-2012, 12:07 PM #6
Member
- May 2008
- Howell, Mi
- 57
changed the filter already. I just checked for power at pump. When I crank it I get power, and if I jump the pressure switch I get power. Really thinking it is a bad pump. Now to find one today
02 Outback LS
Howell, Mi
09-03-2012, 12:55 PM #7
You could try and unhook the line from your pump to your carb and see if it will pump any gas to confirm the bad pump
09-03-2012, 03:54 PM #8
Member
- May 2008
- Howell, Mi
- 57
Turned out fuel pump was the problem. Oreilley's ordered me one, got it in by 2:30. And put it on. Boat is on the water! Just hope this isn't the last day on the water for the year. Thanks for the help guys.
02 Outback LS
Howell, Mi
09-05-2012, 01:52 PM #9
Junior Member
- Sep 2012
- Vidalia, GA
- 16
I have the same problem as boat won't stay cranked. i have read this post and others so i will start in the middle. Please tell me if this is possible....
- The fuel pump does not cycle when the iginition is turned on.
- I have fire but it won't stay cranked when I release the key switch. (I don't have consistent fire.....fires/turns over sometimes....sometimes not)
- If I put the volt meter on the fuel pump I get a reading only when the switch is engaged and only when the engines fires.
- I don't get a reading if the engines does not fire.
- When I disconnect the fuel pump I get a reading on the volt meter every time I turn the ignition switch.
Anyone else have this problem? Does this lead to a solution? Or, am I imagining things?
Where do I find the ECM and the reset circuit switch box? [2001 Moomba Outback LS]
09-05-2012, 02:49 PM #10
