did you buy the boat from Atlanta Marine?
season here is about to start - you need the boat to start!
this might be one that you need a pro to address, IMO.
Results 21 to 30 of 44
Thread: boat cranks but wont start
03-18-2013, 10:30 AM #21
New ride: 2012 Mojo
Old ride: 2008 OBV
03-18-2013, 10:52 AM #22
boat cranks but wont startr
Just so I got this straight, the boat runs fine if you keep pushing the start button? Do you have any pics of the wiring that is spliced at the back and the back of the push button?
I would be looking to undo all the shotty work and fix any wiring that was cut into with solder and heat shrink tubing. I would also be removing the push button and trying a temp key or hot wire to eliminate it as the problem.-Jake
03-18-2013, 10:58 AM #23
Senior Member
- Jan 2008
- Tampa, FL
- 1,361
Based on what you just posted, replace the ignition with a standard key ignition.
2008 Outback
03-18-2013, 11:08 AM #24
Junior Member
- Sep 2012
- Vidalia, GA
- 16
03-18-2013, 11:09 AM #25
Junior Member
- Sep 2012
- Vidalia, GA
- 16
Already installed a standard key ignition and confirmed the wiring is correct.
Thanks.
03-18-2013, 11:09 AM #26
I'm pretty sure that's what he has done, but something is goofed up in the wiring from where the prior owner put in the push button start. Who knows what that person did either under the helm or back at the engine?
You might be able to track down the prior owner and get some idea of what they did. Otherwise, I think you're going to need to rip it all out as Jake stated. It's something I might not take on so that's why I suggested taking it to ATL Marine.Drew
New ride: 2012 Mojo
Old ride: 2008 OBV
03-18-2013, 11:12 AM #27
Junior Member
- Sep 2012
- Vidalia, GA
- 16
03-18-2013, 11:23 AM #28
Junior Member
- Sep 2012
- Vidalia, GA
- 16
Hope this works.
03-18-2013, 01:18 PM #29
Senior Member
- Dec 2006
- Tuscaloosa, Alabama
- 586
My last boat did that. I found that during the start function, voltage went through a resistive wire. When the boat started and you went to the on position the voltage went from the resistive wire to another wire that was fused under the dash. These wires were feeding the coil. My coil was shorted. Got a new coil and replaced the fuse and all was fine. I have no idea if this will help you or not. This was on a 1985 Mercruiser inboard/outboard.
Jack Beams
'05 Outback DD
325HP EFI Indmar
03-18-2013, 03:06 PM #30
Junior Member
- Sep 2012
- Vidalia, GA
- 16
Picture attached. Thanks
