I am installing a ballast system on my 2000 Kamberra (same boat as the Mob V). I went to West Marine to talk about a thru hull fitting and they asked me what the thickness of my hull was. I answered "ummmmm" Can anyone help with this. I am planning on adding the thru hull around the same place that the current one is for the engine cooling.
Thanks.
Keep your plug in
Results 1 to 2 of 2
Thread: Thru Hull Fitting
04-07-2003, 09:15 PM #1
Thru Hull Fitting
04-07-2003, 11:00 PM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Ballast thru-hull
PJTATRO,please contact techservice@skierschoice.com. If you are installing the current ballast system, the intake will be stbd. They may be able to assist in measurements, hole dia. and other documentation to help the ease of installation. Brian Raymond
Hull diferences
By Wakesurfer in forum General ChatReplies: 0Last Post: 08-22-2006, 01:01 PM -
Thru hull scoop
By pmann in forum General ChatReplies: 0Last Post: 06-02-2006, 08:55 PM -
zerk fitting on mob-V shaft
By Cliff in forum General ChatReplies: 1Last Post: 08-23-2003, 10:59 PM -
Thru Hull Fitting
By pjtatro in forum Boat OwnersReplies: 0Last Post: 04-04-2003, 07:25 AM -
Fitting a tower
By Mainemoomba in forum General ChatReplies: 0Last Post: 02-25-2003, 09:04 PM
