hi there.
i have a 1999 moomba kanga and there is something wrong with the fuel pump. it first started when we took off from the dock and the boat died. so we finally figured out that the carb was dry of fuel. and the fuel pump wouldn't prime when we turned on the ignition. so we switched the wires on the pump and it started running. we then switched them back and it ran fine. untill it stopped running again the next day. we tried the same thing but it didnt do anything. so we ran a wire from the positive post of the starter to the fuel pump and that started the pump. so we have figured that it is something to do with the pump wiring. would anyone know how to fix this. where are the relays for the pump ...etc..
thanx Dave
Results 1 to 2 of 2
Thread: fuel problems
08-04-2005, 08:06 PM #1
Junior Member
- Aug 2005
- 1
fuel problems
08-05-2005, 09:13 PM #2
Banned
- Feb 2003
- Spokane, WA
- 57
Replying to Topic 'fuel problems'
Red,
There is a safety on the engine that kills the motor if the oil pressure is to low. This safety switch is located near the distributor. It should/could have 3 wires coming out of it. When I "stroked" my motor to a 383 we had to prime the oil pressure before the fuel pump would work. Some of the guys on the Supra sight have had to replace this safety switch and as they say, it is a very easy replacement for most people.
Hope that this helps. Good luck and keep us posted.
Tygger
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Tax Refund for Boat Fuel
By Will Watters in forum Boat OwnersReplies: 10Last Post: 05-03-2006, 01:14 AM -
01 Outback FUEL/WATER problems
By jeffreyala in forum Service & RepairReplies: 18Last Post: 04-17-2006, 10:54 PM -
engine problems--fuel injector or filter
By in forum Service & RepairReplies: 0Last Post: 06-12-2004, 07:11 PM
