Results 1 to 3 of 3
    Vicksburg, MI
    Default Transmission Screen Cover Wrench
    Since it seems like summer is over up here in Michigan, I decided to change all the oils in my boat today, and attack the transmission screen for the first time. I followed DOCDRS Transmission and Vdrive post, but I found a minor issue with it. The two bolts that hold the transmission screen cover plate are metric, and therefore require a 13mm wrench, not a 1/2 inch wrench. In some cases a 1/2 inch wrench may work, bot not in all. I do not know how long the transmission has been using metric hardware, but it is definately metric in the 2010's. I was going to add this to DOCDRS post, but it is closed. Hope this helps others that have tried.
    Joe
    2010 Outback V
    Rockford Fosgate P500-4 Amp
    Modified Bimini
    Aerial 2 Speaker 3 Light Combo with Kicker KM6200 Speakers
    Upgraded Gravity I to Gravity III
    Added IBS
    Very thoughtful of you to post on this. How did it all work out for you?
    Thanks and the post has been updated
