Results 1 to 3 of 3
    May 2007
    Richmond, VA and Deerfield, IL
    Default Transmission Filter
    Need guidance.
    According to ZF Hurth Marine’s Operating Manual, the fluid filter on a ZF 45 C (direct drive application) transmission is located on the underside of the transmission housing. At least that’s the way it’s shown in the picture.
    Running my fingers along the underside surface of the housing, I have tried in vain to locate the two bolts that hold the filter cover and seal in place. Nothing there. Zip. Zero. Completely smooth surface.
    Direction on locating the filter would be appreciated. Thanks!
    2007 Outback
    2012 RAM Crew Cab
    Stuart
    Tuscaloosa, Alabama
    Interesting Stuart. My dealer told me that they clean the screen after the 25 hr break in and that after that you don't have to worry about it from there on out. Hmmmmm Let me know. I just changed the fluid 3 weeks ago
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Oct 2005
    Durham, NC
    I'm not sure if my 2001 has the same transmission or not, but I do have the two bolts and plate and filter. It is a pain to get to. I have only checked it maybe twice and I am at 560 hours.
    Brian Roberts
    2001 Outback DD
