    Default Indmar 340 cat winterizing video
    This is a V drive winterization video. It gives you an idea of what is involved. With cabs winterization thread, the oil change video and the impeller removal video everything but ballast system winterizing is covered. Let me know what you think. I believe the video is about 8 minutes long. I tried to make it less boring!!!
    http://www.youtube.com/watch?v=O1iync4Pz1g
    Mar 2008
    Calgary, AB, Canada
    Good Video DOCDRS. Thank you!
    The one item that I have never done in four years of DIY winterizering is the dripless shaft seal blowout. I thought those gravity drained when the boat is taken out of the water and the rest of the system is drained. Have I just been lucky that I haven't had a problem ? I have a 07 LS (DD).....maybe it is different on a Vdrive?
    2007 Mobius LS
    Quote Originally Posted by Jon J View Post
    The dripless is self draining, you don"t have to blow it out. On the 09's they routed the cooling from the exhaust quick drain connect, which is too hot of water. I rerouted mine to a cooler supply and capped the old hose off with that shut off valve.
    Apr 2012
    Quebec, Canada
    On my 325 assault, there is a water hose ( I think) that goes in the transmission to cooler it ( I think). Is there something to do to drain the water from there? In every winterizing thread, nobody seems to drain the water from the transmission.....
    Mobius LSV 2011
    This is the hose that cools your dripless driveshaft seal. When you remove your impeller or hoses off the impeller housing your transmission cooler will drain. Then lift the hose running from the cooler to the shaft seal so any remaining water in that hose will drain out the shaft seal.
    Apr 2012
    Quebec, Canada
    Ok so if I understand there is no water that goes in the transmission.........I can see two hose that goes from the transmission to the big hose near the waterpump ( is it the trans cooler?). So what is there in those hoses? I tough it was water but it is probably oil......
    Mobius LSV 2011
    Jul 2011
    Oregon City, OR
    I think the smaller lines/hoses you are referring to are trans fluid lines going to the trans cooler.
    The large hose (1-1/4") is water that passes through the trans cooler.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 surf side v-locker
    650 in the floor locker
    600 to move around
