Page 7 of 20 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 193
  1. #61
    Quote Originally Posted by slingo View Post
    Wow, 1500lbs in the nose...watch out for rollers coming at you when you're slowing down!
    What's the 411 on pumps? The stock ones seem to take quite a while to fill. If I change out the stern 650s for 1100s, It'll take a VERY long time to fill them. Is it advisable to put in a higher volume pump? Additional pumps?
    I'll try taking off the middle fin on my Hyperlite Broadcast and see how that works. IS there a better "intermediate" board I should look at? And what size? I'm 6'5" 200lbs, and my wife is 5'5" 135lbs.
    Surprising with 1500 up front i still have a good 2-3 feet of nose out of the water when she is approaching you at idle
    Pumps will be fine
    Fill time should be apx 1 minute per 100 lbs of ballast. 6-7minutes for the 650s and 10-12 minutes for the 1100s
    That board is fine for what your doing, as in learning, there is another thread talking about boards to try out.
    General rule of thumb, the lighter a board is the faster it is in the water, and the more expensive a board is the lighter and faster it is in the water.
    http://www.moomba.com/msgboard/showt...ards-Which-one
  2. #62
    Nov 2012
    Lake Anna, VA
    Good link. Thanks!
  3. #63
    Sep 2012
    Clearlake Tx
    Ok aftercmuch research order my IBS 650 will be in next week so we can work our surf wave......also have upgraded the rears to 1100 and just got another Acme 1235 to replace the one on the boat to send out and have a spare....will keep everyone updated on install and results......great page guys!
    2012 MOOMBA MOJO 345hp Surf Motor! Gravity III/ Engine water strainer, Heater, Acme 1235 prop upgrade, 2 Wetsounds Rev 10, Wetsounds Syn 4 amp, 12in Kicker substation with amp, Blue LED lights under ski platform, cup holders, speakers and Rev 10 rings! 1100 rear ballast bags, 650 IBS integrated into factory pumps.
    TEAM LOCKHART
    2005 Moomba LSV (traded on MOJO)
  4. #64
    Apr 2013
    Hi guys - I am helping my bud get his new Mojo dialed and want to find out where is a good starting point. He wants a good wave but probably won't run as many bags as OP.
    It sounds like 1100's in the rears and a bow sac might be a good start? Does the Mojo care if the weight is centered in the bow vs. all on one side?
    Thanks!
  5. #65
    1). Post pics
    2). Order 1,100's from wakemakers. They are plug & play
    3). Order IBS, bosworth Y,1" fixed Y and a some hose & clamps from wakemakers.
    4). Install #2
    5). Enjoy a few cold ones
    6). Install #3
    7). Enjoy a few cold ones
    . Go surf
    9). Enjoy a few cold ones
    10). Post pics of you all surfing and enjoying a few cold ones
    New ride: 2012 Mojo
    Old ride: 2008 OBV
  6. #66
    [QUOTE=mmandley;212762]
    [QUOTE]
    you need to ride more boards . . . . .
    The shape and buoyancy are what make a board go faster. Fins also make a difference and quad fin or twin fin set up will offer more speed on a surf style board because there is no fin down the middle like a thruster that holds it back a little.
    Flyboy (Jeff & James Walker) do a ton of prototyping of boards. Sometimes technical, but always entertaining read:
    http://flyboywakesurf.com/
    While these were written specific to traditional surfboards, the terminology is basically the same for wakesurfers:
    http://www.islesurfboards.com/surfbo...damentals.aspx
    http://allaboutsurfboards.com/surfboard-bottom/
    New ride: 2012 Mojo
    Old ride: 2008 OBV
  7. #67
    [QUOTE=wolfeman131;212817][QUOTE=mmandley;212762]
    I will check that out but i have ridden more then a dozen different boards and almost all of them have been different styles of surf and my general finding is exactly how i put it. Some boards are heavy such as a couple IS board and they are fast but nothing is as fast as the Soul Craft i have and like i said a lighter board will be faster in the water because it too has less drag.
    Also some, but not all boards that have 3 fins will be faster by removing the center fin.
    On my Soul Craft its faster by removing the 2 smaller fins and also replacing the rear fins with slightly smaller ones makes it more maneuverable.
    Also another consideration is Rider Weight, if your light or well under the boards maximum weight limit the board will of course be much faster then if your heavier and closer to the boards weight limit.
  8. #68
    Fins make a big difference if the rider is heavier and sinking the board deeper in the water. In other words, different sized riders may feel different things from the same fin setups.
    fins 101:
    http://www.surfing-gear.net/surfboard-fins.html
    A number of pros are now running up to 6 fins on surf style boards. The number of fins shouldn't impact the speed of the board, it's the size of the fins, specifically the base.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
  10. #70
    This impacts the board's buoyancy. If you're too heavy for a board, you are impacting the bouyancy (i.e. sinking it) and therefore not gaining the full potential of the design. Ultimately, this is why there isn't a "one size fits all" surfboard.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
