Page 9 of 20 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 193
  1. #81
    Don't worry I don't work for a chocolate factory or a bank
    2012 Moomba Mojo 2.5
    ACME 1235 prop
    Wakeboard Hyperlite Belmont
    Wakeskate Hyperlite Byerly
  2. #82
    Must be a ski instructor or guard the Pope or something.
    Pope guard haha funny! you forgot watchmaker. I work for swiss air navigation services as a technical supervisor (something like FAA in the U.S)
    ACME 1235 prop
  4. #84
    gurt,
    I wasn't following all the Swiss stuff. Wish I would have known as the Swiss Wakesurf Championship was just held a few days ago. Some of the best women riders in the world were there including Rebecca Ort & Raleigh Hager. It's a stop my family hopes to make it to in the next 2 yrs.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
  5. #85
    ok, I didn't know about this championship. I posted a picture (it as to be checked by moderator) of your ballast setup that I've done (like yours) but a bit more detailed (to be sure that I understood it well).
    ACME 1235 prop
  6. #86
    Post approved.
    Dang it, can't believe I forgot about watchmaking and the army knives.
    cheesemaker...
    Maybe the hose between the 370 vent and the left 1100 can be 1" because it's used to fill ?
    ACME 1235 prop
  8. #88
    yes, you could actually upgrade all the vent lines to 1" while you're at it. factory has done this for '13 and going forward with the thought that if you're pumping water in thru a 1" then you should be venting with 1" to avoid any issues.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
  9. #89
    Ok, thanks for info (it seems to be logic to have the same section everywhere). So my schematic is correct ?
    The TH off the boat are ok for the 1" or do I have to replace them ?
    Thanks
    ACME 1235 prop
  10. #90
    I checked everything and my order is placed (I took some TH 1" in case I have to replace the stock one's) and hope I forgot nothing ! (I always took one extra items of each except the bags ). Just have to wait now...
    Thanks for your help guys ! to be continued...
    ACME 1235 prop
