Has anyone installed the perko flush kit on a v-drive?
Just wondering where you installed the water inlet, I need a good mounting suggestion. I was hoping for something that could be mounted outside/thru hull but the one that comes with the kit isn't going to work..
Guessing someplace near the engine..![]()
Thread: Perko flush kit install...
10-17-2012, 08:00 PM #1
Senior Member
- Aug 2011
- 370
2002 Moomba Mobius LSV
10-18-2012, 08:26 AM #2
I didn't install it, but mine is mounted at the water intake just to the right of the V drive, down low (just an inch or so above the bilge floor)
2005 Moomba Mobius LSV
10-18-2012, 11:05 AM #3
Senior Member
- Aug 2011
- 370
10-18-2012, 11:54 AM #4
Yes, just pick up the back seat and off with the v-drive cover...
I'm not sure what you meant by the oops part, but I can take a pic of it tonight if you think it would help...===================================
10-18-2012, 05:32 PM #5
Senior Member
- Aug 2011
- 370
I installed the perko flush and winterized my boat this afternoon...
Is your water inlet under the v-drive cover as well?
I have the kit so it has an external water inlet that you install in the transom. however I think it's going to get into the way on the back. I think I'm going to fab up a small bracket and put it under the sundeck near the engine. This way I only need to lift the sundeck and connect the hose...
Looks like this one..
34439.jpg2002 Moomba Mobius LSV
10-27-2012, 07:21 PM #6
Do you guys have any pic's of the mod? Very interested in seeing this, I've got an 04 Mobius LSV. Cheers
2004 MOBIUS LSV
2008 Tacoma
10-30-2012, 12:08 AM #7
Senior Member
- Aug 2011
- 370
No pics, boat is all wrapped up, did you get it installed? I didn't install the inlet in the rear, will probably make a mount for it in the engine compartment so I can control the water while on the boat.
Sent from my HTC Sensation 4G using Tapatalk 22002 Moomba Mobius LSV
