Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
    May 2011
    Fort Worth
    Default installing a second battery
    ok, I plan on doing this possibly this weekend. I have done a seach on here but I really need it "dumbed down". Does anyone have a really simple diagram they could share?
    Casey
    '08 Mobius LS
    Casey
    You just adding a second battery? No switch?
    Second Battery is simple Positive to positive and Negative to tegative. It will be 1 big 12V battery.
    If your using a Switch system post up the one your using.
    May 2011
    Fort Worth
    Perko switch... sorry, I thought that was a given.
    '08 Mobius LS
    Jun 2010
    Lake Houston
    There's an absolutely amazing drawing in the owners manual. I'll see if I can find it electronically.
    2013 LSV
    2005 LSV - SOLD
    Jun 2010
    Lake Houston
    Page 63......
    There's an even better drawing in the 2013 manual
    http://www.google.com/url?sa=t&sourc...G_ESCYRNpXYY6A
    2013 LSV
    2005 LSV - SOLD
    Sep 2012
    Chattanooga, TN
    In my opinion, this is the best way to do it:
    http://www.mastercraft.com/teamtalk/...ead.php?t=3557
    This is how I've done mine and it works great. It costs you about the same amount of money on the Perko, but it's automatic. So you never have to mess with setting "1" "2" or "OFF" manually.
    This is the relay that you would want:
    http://www.amazon.com/BorgWarner-R30...g+warner+relay
    Although you can probably find it cheaper at O'Reilly's or similar place. It was easy to hook up; just follow the drawing in that thread.
    2005 Moomba Mobius LSV
    May 2011
    Fort Worth
    Hmmm... does the same wiring apply if their is a switch, not a relay?
    '08 Mobius LS
    Sep 2012
    Chattanooga, TN
    Yes. The only thing that I can think of that would be different is that you do need to run a wire (say a 16 gauge) from the ACC on your ignition (the purple wire) to the relay, so that it will automatically engage the relay when you turn the key.
    Basically a relay *is* a switch, it's just controlled by another electrical signal (in this case, the ACC terminal on your key), instead of you having to reach in the battery compartment to do it yourself. Convenient.
    And here's a cheaper place to buy the relay:
    http://shop.advanceautoparts.com/web...ntent=10711125
    Sep 2012
    Chattanooga, TN
    And just to clarify what the relay is doing, it is this:
    1) it is in the "open" state while your key is in the off position. This means you can run your stereo and whatever else you have hooked up to battery #2, while preserving the charge of battery #1. In "Perko" language, the switch is set to "2".
    2) it is in the "closed" state while your key is in the ACC or crank position. This means that whenever you turn your key to crank the boat, both batteries are acting as one big battery. In "Perko" language, the switch is set to "1 and 2".
    Has worked great for me. The only negative possibility is that it is theoretically possible to run down batt #2 so far that when the relay closes, there is a significant draw from batt #1 wanting to charge it that you can't crank. Reading the thread mentioned above, I came to the conclusion that the original poster has physically tested this and it doesn't seem to happen. Even in the case that it *does* happen, all it takes is a simple disconnection of the positive end of batt #2 to the relay, and then you are operating only with batt #1 which should be fresh. Trivial to do in the event that this occurs.
    Return the perko and get a battery isolator, no messing with switches...
    http://bluewatermarinesvc.com/html/bat_isolator.html
    2006 Moomba Mobius LSV
