Mine wasn't long enough to thread out of the bilge drain hole in the back of the boat....is that supposed to be the case? I ended up sucking out the oil with a Pela extractor, but figured that it would have been easier if I could have just drained it directly into a pan...
Results 1 to 3 of 3
Thread: Dumb Q about oil drain hose
11-28-2012, 01:02 PM #1
2005 Moomba Mobius LSV
11-28-2012, 01:21 PM #2
nope, you did it the right way.
I think a few have made extensions for the hose so they could run it out the rear drain, but the majority are using fluid extractors.Drew
New ride: 2012 Mojo
Old ride: 2008 OBV
11-28-2012, 02:08 PM #3
Some of us run it out the transom drain AND use fluid extractors... I have a Jabsco impeller fluid extraction pump setup mounted on a utility cart I hook to the end of the oil drain hose to the inlet hose of the Jabsco (brass fittings to match the fittings on the oil drain hose) which I ran into the bilge thru the transom drain, then have hooks off the side of the cart I hang empty gallon oil jugs off of and put the output hose into one. Remove the filter and drain it into a jug, and kick off the pump. It creates vast amounts of suction and in 2-3 minutes the engine has been emptied of oil. After it starts sucking air I'll turn it off and leave it sit for a half hour then run it again for bit to get the little bit that drain down... works like a charm.
Kraig - 2010 Outback V
