I am going to be building some sub enclosures for our 28’ pontoon boat that we use as a landing pad while out boarding. It has an upper deck, where the kids hang out and jump off of.
I was planning on building the enclosures for the upper deck to hold to 12” subs in a removable (for towing clearance) seat base and two more for the lower deck area.
Can someone give me some suggestions on the following subs; I love the JL Audio W6 subs but at around 6 bills a pop and I plan on having four…
JBL GTO1214 ~$80
12" Single 4 ohm GTO Series Car Subwoofer
JBL GTO1214D ~$75
12" Dual 4 ohm GTO Series Car Subwoofer
MB Quart PS3-302 ~$65
12" Dual 2 ohm PS3 Series Car Subwoofer
MB Quart PS3-304 ~$65
12" Dual 4 ohm PS3 Series Car Subwoofer
Kicker CVR124 (07CVR124) ~$75
12" Dual 4 ohm CompVR Series Car Subwoofer
Thanks for any help, Eric.
Results 1 to 10 of 30
12-07-2012, 12:54 PM #1
Senior Member
- Jun 2012
- On a NorCal Lake
- 175
Help pick cheap subs for our pontoon boat...
12-07-2012, 03:15 PM #2
not sure on what amp(s) you plan on using, but you have 3 different ohm ratings there so how are you going to hook them up?
I'd probably buy the quart if it was me as i've never used their stuff before and it would give me a good chance to test it out at prices that aren't going to break the bank..'06 Supra Launch 20SSV-gone but never forgotten
12-07-2012, 04:24 PM #3
Sand is on to something here for you. Start with the available power you have amplifier wise. Some amps can handle 1 ohm loads, and others cannot. Even if you are planing on running 2 different sub amplifiers, the sub question still needs to start there. The key is going to be to match up the correct subs, to correct amplifier, regardless of brand involved. Make sense?
Sounds like this is going to be a nice party once the upgrades are done.
-Brian
12-07-2012, 04:31 PM #4
Senior Member
- Jun 2012
- On a NorCal Lake
- 175
Thanks for the reply guys, but as this is a complete new system, as I dont have anything yet except the boat, I have the luxury of being able to match amps to subs.
So, anyone have good/bad experience with any of these subs? I have really only used JL Audio for the last 10 or 12 years.
Eric.
12-07-2012, 04:53 PM #5
Member
- Feb 2011
- Dallas, TX
- 92
Eric I had one of these in a sealed box with 400 watts going to it and it hit. Was surprised how good it sounded for as cheap as i got it
Kenwood KFC-W3013PS
Sonicelectronix.com has it for $552009 LSV Liquid Force Edition
- Gravity III
- Z5 Rack
- ACME 1847
- Polk MM6501UM - Kicker IX500.4
- Kicker CompVX 12" - Kicker IX1000.1
- Pair Wetsounds Rev 10s - JL Audio HD750/1
- RGB LEDs
12-07-2012, 04:57 PM #6
EricU,
I have tons of experience doing boathouses, pontoons, house boats, and yachts with a flybridge. In other words, on elevated surfaces with little in the way of reinforcing planes. I also have years of experience doing back yards, systems around pools and exterior commercial sound. Believe me, a different set of acoustic rules apply versus what you may have experienced in your towboat.
I have a different type suggestion regardless of which woofer you select:
Do NOT place subwoofers on the upper deck. A single well-designed woofer/enclosure located on the lower deck could easily out-perform four upper deck subs. The farther you get from the water level the less bass you will be able to create. The more you spread the subs out or attempt to disperse the bass the less bass you will have. Also, the amount of supply current and amplifier power you will waste trying to develop sound pressure at lower/longer frequencies from an elevated position is staggering.
Try this simple experiment. Take your home HiFi or theater sub and set it out in the middle of the back yard. You will be shocked at just how anemic the sub becomes. Now, set the sub atop a ladder in the middle of the back yard. It gets much worse. You may get some midbass but you will not get ANY deep bass no matter how hard you work that sub. There are inescapable physical reasons for the losses.
12-08-2012, 12:13 AM #7
Holy heck on the Sub analogies.
When your done running laps around your back yard with the subs.... (wait you don't have subs?), Take it indoors and put it near a wall. This is called boundary loading and gives a nice lift in the response. Position it next to two walls and it sometimes be double wow. In my last house, I actually built the subs into the floor and ported them up thru air vents in the hardwood floor. It was awesome because people never saw any enclosures. Wait, back to this thread.... I think you where just looking for sub advice, right?
Double wait--- I got it. Lets park the pontoon in the back yard and rock it. Thats the ticket. Anyone got a meter?
My comments are meant to be light hearted here. I think maybe we should make a poll (not sure how to do that), and we can vote on the subs he posted up?
-Brian
12-08-2012, 06:50 AM #8
Senior Member
- Sep 2010
- Lighthouse Point, FL
- 214
Holy Crap Batman, remind me never to ask David for sub advice!!! I do beleive the OP asked for suggestions on subs not your resume.
Have you ever been to an outdoor concert? If you notice they have speakers, including subs, mounted angleing down, and get great sound. Im sure some audio engineer has done a lot more research in how to make it work then anyone here.
My suggestion is to follow that concept when building your enclosure.
hey I still didnt answer his questionREALLY????
12-08-2012, 08:15 AM #9
Bak to op I guess.
Don't have experience with those brands, but with Polk and exile, question was cheap so exile is out,
These are Marine certified and cheap, sound pretty good for the price.
http://www.sonicelectronix.com/item_...DB1240DVC.htmlA Day at the Lake...Priceless
12-08-2012, 08:18 AM #10
I'll try to sum it up......choose which ever sub you want, as they will all sound like poo poo if executed poorly. This is a message that is repeated time and time again, the best sub is the one done properly. 9 out of 10 times, the folks with the interdependent opinion, get hammered by those in a certain brand camp, when they do not recommend the brand of choice. In this case, its kinda funny because David is getting flamed, by a manufacturer of a brand not even mentioned, of all people, for simply offering some install advice. David has far more audio, car audio and marine audio knowledge and experience then anyone else on this forum, and many other forums. I even bounce ideas off him and get advice from time to time from David about particular install hurdles that come up.
Back on topic, I would agree with David in regards to the subs location. Placed on the top deck of an aluminum pontoon, is not going to offer that boundary-loading that was mention. The dual sub box/bench seat is going to be a great treat for a couple ladies that get to sit on it, but is going to be lacking for the rest of the boat. I thinks its going to sound kinda flat and weak at best, and is going to do more to rattle the aluminum frame of the deck, rather then benefit from it as we would see with a dense solid structure.
