I have a 2001 Outback with the stock 310 HP motor. I put an OJ 13X13 4-blade prop on in place of the stock 3-blade. I've been told by other boat owners that you calibrate the speedos by cruising with the motor at 3000 rpm. This speed should be 30 mph and to adjust the speedos accordingly. Is this true? Thanks.
Results 1 to 6 of 6
Thread: Speedo Calibration
04-23-2003, 03:39 PM #1
Junior Member
- Feb 2003
- Chicago
- 12
Speedo Calibration
Pman
04-23-2003, 06:27 PM #2
Member
- Jan 2003
- Nashville
- 57
Let me know how you like that prop. Thinking about going to a 4-blade.
04-23-2003, 11:33 PM #3
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Prop vs. Speed
Pman, I feel you will be happy w/your new 4bl. You should notice a quicker hole shot, which the skiers and footers will enjoy, and be able to hold your speeds much better. For the boarder, it is nice because it lifts the aft end up and forces the bow down at lower speeds to get more boat in the water for a bigger wake, and not have a bow high take-off, even when loaded. Todays high h.p. and torquey motors engineered by Indmar, have changed the rule of thumb a bit on the 4bl. Set your speedo at 36mph@3800r.p.m., this will get you darn close to the high $ G.P.S. Brian Raymond
04-23-2003, 11:34 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Prop vs. Speed
04-24-2003, 04:36 PM #5
Junior Member
- Feb 2003
- Chicago
- 12
4 blade prop
Brian, thanks for the speedo calibration. And yes, the 4 blade makes a difference out of the hole and maintaining speed. The first season I owned the boat it was with a 3 blade. I purchased an OJ force 4 blade mid-next season and definitely saw a difference. At the time, stainless 4 blades weren't out (by OJ), but would like to try one someday.
Pman
04-24-2003, 05:18 PM #6
Member
- Mar 2003
- Mississippi
- 67
If you can borrow a GPS from someone this is a very easy and very accurate way to calibrate your speedo. You can also check it at any speed.
2000 momba balast and speed calibration
By yzblue125 in forum General ChatReplies: 4Last Post: 01-03-2005, 04:06 PM -
Perfect Pass Temperature Calibration
By Shoemaker Mobius in forum Service & RepairReplies: 2Last Post: 05-18-2004, 10:01 AM -
Speedo calibration
By cola in forum General ChatReplies: 8Last Post: 09-05-2003, 11:36 PM -
Calibration Knob for Speedo
By marvmoose in forum Service & RepairReplies: 2Last Post: 08-27-2003, 08:55 PM -
Speedometer calibration
By sloppy in forum Boat OwnersReplies: 2Last Post: 08-02-2002, 08:17 PM
