There is no salt water in the engine or exhaust system on an indmar assault ss. It is completely closed. It has tanks and a circulating pump.
Results 11 to 20 of 23
Thread: Etx cat manifold problem
12-25-2012, 01:55 PM #11
-Jake
12-25-2012, 02:09 PM #12
The cooling raw sea water has to be expelled some where ......most likely just after the exhaust manifold where the tstat housing exhaust dump hose is located on a non sea water unit, just after the exhaust mani to cool the muffler. It is probably close enough to still cause corrosion in this area......how about a larger pic of the motor area??
09 21v LAUNCH
Doug
12-25-2012, 09:21 PM #13
Senior Member
- Dec 2006
- Tuscaloosa, Alabama
- 584
Thats what I was getting at with what DOCDRS said. Somewhere raw sea water has to come in and it has to go out. Somewhere is a heat exchanger.
Jack Beams
'05 Outback DD
325HP EFI Indmar
12-25-2012, 10:59 PM #14
Quote from Indmar saltwater series engines:
"Indmar SaltWater Series cooling systems are completely closed loop systems. That means salt water will never enter the engine system or the exhaust manifolds."
Again, salt water "will never enter the engine system or the exhaust manifolds."
Here's the link: http://www.indmar.com/Engine/moomba/5.7lassault345.aspx2007 Outback
2012 RAM Crew Cab
Stuart
12-26-2012, 09:24 AM #15
Senior Member
- Dec 2006
- 584
Interesting. Don't know how that works exactly but pretty cool
Jack Beams
'05 Outback DD
325HP EFI Indmar
12-26-2012, 12:01 PM #16
I read that too , but there is also this
If you use your boat in Salt or Brackish Water Ride Australia and Supra boats recommend a fresh water cooled engine or the salt water series engine. Salt Water series and fresh water series engines still require flushing.
The cooling water has to be discharged into the exhaust (which is not the exhaust manifold) to keep the exhaust rubber and fibreglass muffler cooled. Depending where it is dumped in (see pic) corrosion could definitely occur at the housing interface. An exploded view (pic ) is needed
exhaust corrosion.jpg09 21v LAUNCH
Doug
12-26-2012, 07:55 PM #17
Interesting. Wish I could see more pics. The difference between the FWC and FFWC was that on an FWC engine it was common to have to replace the riser every couple of years even with flushing the raw side of the system regularly.
On the FFWC engine you eliminate the riser corrosion issues.
That's all I was saying, both systems are considered full fresh water systems. I definitely agree you still have to flush the raw side of the system regularly. As JMB said it still has the exchanger.-Jake
12-27-2012, 02:17 PM #18
Jake, I was not trying to contradict you , just further the thread on how corrosion may have happened. And yes, I too would like to see ( on his engine) where they dump the water to cool the muffler otherwise the rubber and fiberglass would melt from the heat. The cat exhausts I think has allowed them to close cool the exhaust mani/risers as they are a single casting
09 21v LAUNCH
Doug
12-27-2012, 07:54 PM #19
Senior Member
- Dec 2006
- 584
Thats where I'm at with this Doc. Not going to argue though. The exhaust has to be cooled one way or the other.
Jack Beams
'05 Outback DD
325HP EFI Indmar
04-14-2013, 03:21 PM #20
Junior Member
- Dec 2012
- CA
- 6
Guys I don't know if your still around this thread, I'm sorry for the late reply I went to work abroad for a couple of months and was away from the boat or forum.
I ended up changing the etx cat manifolds which did cost me a lot!
Doc you are right and the picture you posted looks a lot like my engine I just have a heat exchanger more, the raw water is expelled thru those stainless steel elbows which might have caused the corrosion in that area.. Other possible causes of this is that I have mixed diff type of coolants, using the throttle when in reverse (which can lead to that raw water is pushed up), salt water dripping over engine compartment(from boards and ppl coming out of the water)
I'm still not sure what exactly caused the problem.. Although I do flush my engine with fresh water every time I use it.
Thanks a lot and sorry again for being late.
Cheers
