Does anyone have an electrical schematic for a 99 Outback LS The boat was bought in 2000 All of my gauges have no power. All of the other electrical is working.
Also, The Speedometer Hoses are connected to a module under the dash. The plastic where it is "glued" to the spedometer module came off. What should I use to re glue that plastic to the module???????
ANY HELP IS Greatly appreciated! LOVE THE BOAT, JUST DIEING To get the speed so we can go footing!!!!!
Results 1 to 8 of 8
Thread: Speedometers/Gauges
06-01-2002, 10:47 AM #1
Junior Member
- Jun 2002
- Wisconsin
- 9
Speedometers/Gauges
06-03-2002, 09:34 AM #2
Member
- Apr 2002
- Greenfield Indiana
- 79
I feel your pain
I to have had that problem with our 2000 Outback/LS. I have had no instruments and at times partial (tach no speedo). We have tried a few different things, swap connections, replace gauges & clean pickups with no permanent luck.
I called just this past Friday and spoke with Rob & Skiers Choice and he was Extremely helpful in diagnosing the problem and proposing a fix. For me, that meant having my dealer order a new blackbox that decodes all of the information being sent for instrument readouts. They have seen this before and feel it will be the right fix for me. Give them a shout or ask your dealer, this could be your fix to.
Good luck with the footen
06-23-2002, 08:00 PM #3
Junior Member
- Jun 2002
- IOWA
- 3
MY SPEEDOS NEVER WORK RIGHT IM SAVING MY $$ FOR A PERFECT PASS
JKK
06-23-2002, 08:01 PM #4
Junior Member
- Jun 2002
- IOWA
- 3
JKK
07-09-2002, 10:06 AM #5
Junior Member
- Jul 2002
- Woodbury, Tennessee
- 10
gauges
We have had trouble in the past. The Kaiser Medalion gauges were a poor choice by Skiers Choice. They have now changed brands. Try turning your key to the on position and letting all the gauges reset and power up before you start the engine. This will help, but you will always have trouble as we have.
07-18-2002, 06:15 PM #6
Junior Member
- Jul 2002
- san jose, ca
- 4
Speedo/Electrical
Yup! Had that problem from day one. It now has subsided but came back with 2500 extra hours on it!! Just a little surprise for us!! We are hoping that they will actually believe us when we take it in
Still love our Moomba Baby though!Phil 4:13
06-25-2003, 11:51 AM #7
Junior Member
- May 2003
- michigan
- 3
speedo and Kysor Medallion issues
Most of the Black box (MDC) issues can be cleared up by running a dedicated ground and battery to it. The factory installed ground is not good enough for a computer system to run correctly. Just doing the ground and power will clear up most of the problems. You will not find a more accurate speedo than this system.
If the speedo inputs have broken or leak it is caused most of the times by the installation not letting the water drain out of the tubes. This will let the water freeze during the winter braking the seal. Make sure the tube has a place to drain before storing for the winter. Just make sure the computer is higher than the tube.
06-26-2003, 09:06 PM #8
Junior Member
- Feb 2003
- 18
Separate hot and ground
gaugeman,
Canyou elaborate a little on your fix? Are you talking about starting at the battery posts and running directly to a connector at the module? What method is used to connect to the module? Recommended wire gauge? Anything else?
Thanks!
Re-arranged Gauges
By cab13367 in forum General ChatReplies: 11Last Post: 06-30-2008, 01:38 AM -
Two Speedometers?
By cpudoktr in forum Boat OwnersReplies: 16Last Post: 04-11-2008, 01:16 PM -
all my gauges just quit
By yzblue125 in forum Service & RepairReplies: 4Last Post: 06-08-2006, 03:06 PM -
Speedometers stopped working on 2005 Mobius LS
By pls4912 in forum Service & RepairReplies: 5Last Post: 07-25-2005, 11:59 AM -
Instrument Gauges
By hammons0814 in forum Service & RepairReplies: 4Last Post: 09-13-2004, 12:02 AM
