Results 1 to 2 of 2
    Default Adding a Ballast System in Ski Locker
    During the "off season" I am going to add a ballast tank to the ski locker in my Mobius LS. My plan is "T" off the existing pump in the engine compartment to go to the ski locker and then "T" into the bilge pump line to pump the water out.
    My question to those who have the ballast system in the ski locker is how do you get the 2 lines (in and out) from the engine compartment to the ski locker? I believe there is an existing hole with some sort of plastic piece in the hole, do you use this or drill new holes? Needless to say, I am very nervous about drilling holes in my boat.
    Sep 2002
    Default Replying to Topic 'Adding a Ballast System in Ski Locker'
    AZ_Calling, It is just a plastic tub that lines the ski locker, you can pop right through it with a hole saw. Follow your battery cables it should give you an idea of what you are dealing with.
    Good luck,E
  1. Adding factory-style ballast to center ski locker?
    By iaonbb in forum General Chat
    Last Post: 11-22-2006, 02:37 PM
  2. adding on to factory ballast system
    By pickle311 in forum General Chat
    Last Post: 01-27-2006, 05:25 PM
  3. Outback Owners..Ballast in Ski Locker?
    By e420x in forum General Chat
    Last Post: 09-28-2005, 04:38 PM
  4. Size of LSV locker - for ballast
    By jchamlee in forum General Chat
    Last Post: 07-13-2004, 02:01 PM
  5. Ballast for Ski Locker 03 Mobius
    By Bigairdad in forum Boat Owners
    Last Post: 07-07-2003, 10:56 AM
