Is anybody else experiencing a high failure rate of your water pump. We have a 2000 Outback/LS w/Indmar engine and had to replace the pump June 2001. Closed out 2002 season with it making some noise and now have another failing.
Courious if I am just lucky this way or if others are seeing the same results.
Results 1 to 6 of 6
Thread: Indmar Water Pump
04-30-2003, 12:03 PM #1
Member
- Apr 2002
- Greenfield Indiana
- 79
Indmar Water Pump
04-30-2003, 10:15 PM #2
Senior Member
- Apr 2003
- Powhatan, VA
- 316
water pump
Our 99 outback has been leaking some water from the waterpump for 2 summers. Water appears to discharge from the shaft bushing and gets slung by the lower pulley all around the front of the engine ( just like the water pump on a car engine when it goes bad ).
Is this what you experienced? Where do I get a replacement?
05-01-2003, 08:57 AM #3
Member
- Apr 2002
- 79
Thats the failure I have had. The pump itself is a crossover piece and does not have to come from a Moomba/Supra dealer (unless you are under warrenty) Most large marine repair will stock. It seems to run around $130 in the region I am buying from.
I would like to know if there is anything an owner can do to help prevent this bearing/seal problem.
05-01-2003, 11:01 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Circulation Pumps
Unfortunately, there were some pump issues on some motors from '99-'00. I strongly suggest staying with O.E.M. parts, whether under warranty or not. Either purchase the pump through the dealer, or from Indmar,(www.indmar.com). Please make sure to have hull # and motor #(starting w/IC) readily available.Brian Raymond
05-02-2003, 08:46 AM #5
Member
- Apr 2002
- 79
Thanks Brian,
Is there any way to know the manufacture's date of the Indmar water pump. I am going to have to replace again soon and would like to avoid the 99-00 parts stock if possible.
06-12-2003, 11:04 PM #6
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Circulation pump
All of the replacement circ. pumps have the updated seal.Brian Raymond
Raw Water Pump Removal
By dtlaine in forum Service & RepairReplies: 8Last Post: 07-10-2008, 04:11 PM -
Water Pump Leak
By tlrowe in forum Service & RepairReplies: 5Last Post: 08-14-2007, 07:52 AM -
Raw Water Pump
By TobesDubai in forum Service & RepairReplies: 2Last Post: 03-03-2007, 08:23 AM -
water pump wobble
By james yarosz in forum Service & RepairReplies: 1Last Post: 06-15-2003, 10:30 PM -
water pump
By Mainemoomba in forum General ChatReplies: 3Last Post: 06-09-2003, 10:05 PM
