Results 11 to 20 of 37
    Belton, Texas
    To bad your not a little closer to TX Benson
    2009 Moomba Mobius LSV
    I was thinking too bad he wasn't in the ATL.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Jan 2003
    Minnesota and Wisconsin
    Don't misinterpret knowledge for skill. I lived around concrete work while I was a kid. But only have direct experience with fake stone in one case. My son and I did his fireplace surround a couple years ago. Turned out really well.
    Most important lessons learned -
    1. I don't like cement board
    2. It is very easy to go from too dry to too wet when mixing mud -so add water sparingly. This applies to the scratch coat, the 'butter', and the grout.
    3. You MUST butter the back of the stones, even if you are laying them on a horizontal surface.
    4. You can cut fake stone with a recip saw if you get a good diamond blade - but it will generate a lot of dust. I like it better than a circular saw (did not have a tile saw). When you use a recip saw use some duct tape on the blade hilt and on the stone to protect from marring the stone while you cut.
    Good luck.
    http://bensonwdby.home.comcast.net/
    1999 Mobius - DD - 5.7L Carb - Perfect Pass
    Belton, Texas
    So Scott is the only one here with an outdoor kitchen and Benson has the knowledge..... Guess when mine is done ill have to have a moomba forum shindig at the new bar and grill.
    Belton, Texas
    Project is well under way and if all goes well should be done by next weekend. Slab is being laid Monday at 9am, then roofer and electrician follow once slab is dry. I dug some nasty holes today and have much respect for any professional post hole diggers out there. Here's a few shots of the progress thus far
    Belton, Texas
    Site prepped and ready for concrete and roofer
    View from back patio
    Nov 2009
    Are you going to do flag stone or stamped concrete?
    Either way it looks great.
    -Mark
    02 Mobius LSV - GIII Ballast - Kicker 6500.2 Six Pack powered by 650.4 - Polk cabins, 10" L5 powered by Kicker 750.5 - Perfect Pass wakeboard pro
    "Hey you only live once"
    Belton, Texas
    Default Outdoor Bar/Kitchen
    going with the washout concrete. the color and texture of that slab should flow well with the brick and stone that's ready in place. didn't want it to be to "busy".
    sent from my home phone
    Belton, Texas
    Couple of updated shots. Almost done....
    She's really coming along. Should be ready just in time for the hot weather when you have to go inside in the AC.
