Results 11 to 20 of 35
    Aug 2012
    Jan 2011
    Quote Originally Posted by jfox8807 View Post
    says "sorry this link is private"
    Aug 2012
    Ok sorry I fixed it now. Idk how I made it private maybe it'll work this time for u lol.
    Jan 2011
    Yes, that link works now. I've never owned any subs other than home theater stuff (have a couple 15" velodynes in my HT) but man is that level of cone displacement normal??? That looks like it's going to self destruct!
    Sure, if a woofer is constructed with multiple spiders, an over-roll surround and a really long voice coil, it can safely exhibit that type of excursion. Now, that doesn't mean there is much control or pitch accuracy when driven like that. And the finer transients are definitely lost in the modulation. But it certainly looks impressive and moves some air on a synthetic bass burp.
    My vote for exile.... But I am biased as that's all I own.
    Sep 2012
    Cass Lake, Michigan
    Thanks to everybody for the support!
    - Does anybody have any recommendation for a minimum wattage to put through the tower speakers?
    - Is there an off-the-shelf solution for a quick connect where I pull the speaker wire through the hull & into the tower?
    - sandm: How much wattage are your running through the 12w6?
    2008 Outback V
    Loaded Out...Just add ballast and women.
    2012 winter projects:
    - Tower Speakers
    - Sub Woofer
    - Amp Upgrade
    - Head Unit Upgrade
    We've experienced just about every combination and the 12W6 loves the JL Audio HD750/1! JL subs are conservatively rated on their thermal capacity. In an open field environment it's a good idea to fully meet or marginally exceed the thermal rating.
    An 'honestly rated' unregulated 1000 watt amplifier (@14.4 volts supply) may only deliver 750 watts with a 12.6 volts supply. 14.4 volts isn't realistic. 13.7 V may be measured as the alternator/battery combined voltage at 3K rpm. 12.6 volts is more realistic measured at the amplifier primary terminals when under load.
    The strictly regulated HD750/1 is 750 watts guaranteed at any voltage above 11 volts.
    And with the higher efficiency of this Class D amplifier, the supply voltage will sag less at the same power level. That is a bonus to the entire audio system and charging system.
    1) depends on the speaker size and type.
    2) Yes. There are some in-line connectors or surface-mount male/female connector bodies that allow for disconnection of the tower speaker leads in order to fold the tower.
    Sep 2012
    Cass Lake, Michigan
    MORE QUESTIONS:
    - Because I'm putting the subwoofer in, can I get away with a smaller tower speaker?
    - In order to get good sound do I need to step it up to an iCON 8/10 in the Wetsounds or can I get away with a Pro80 to save some $?
    - Does anybody have a thought on the Wetsounds Pro80 vs. the Exile XM7?
    - How are people mounting their amp racks in this hull?
    Again - thanks to everybody for the support!!!
    2008 Outback V
    - Tower Speakers
    - Sub Woofer
    - Amp Upgrade
    - Head Unit Upgrade
