Results 11 to 20 of 23
    Default Re: LED Light Project
    Inspiration..
    https://www.youtube.com/watch?v=MX1O...e_gdata_player
    2002 Moomba Mobius LSV
    Belton, Texas
    Default LED Light Project
    I'm not looking at doing anything in the water. just wanna throw some strips in the interior along the sides, bow, foot well where sub is and maybe the drink holders
    sent from my home phone
    2009 Moomba Mobius LSV
    Oznium seemed to make a pretty good strip. I've been happy with mine but haven't looked at anything else.
    Dusty replaced our courtesy lights with single matching bulbs and tied it all into courtesy. Simple but effective.
    2006 Supra 24SSV
    The thin silicone encapsulated cut to length every 3 LEDs are great for speaker and cup-holder rings, but are not robust enough IMO, to do along the floor or anywhere that they might be contacted by occupants or gear. I would suggest a more rigid strip or pod.
    Jan 2013
    KG, do you have a supplier for the courtesy light replacement led's? I want to pull those dingy bulbs and getting something that is brighter.
    Bill D.
    Quote Originally Posted by txnight View Post
    Bill D.
    What he said ^
    Sent from my iPhone
    times 2 ...........
    We used the prewired super flux. Just spliced the factory wire and put these in its place.
    http://www.oznium.com/prewired-superflux
    Some pics from ours that got archived
    "I've had a few PM's from people asking about the LED's and what all we did, so I figured I would just post my process. Everything is powered by the factory courtesy light wiring, off of that switch, even what we added. For above the cup-holders, the Supras already had a small 3 LED unit above them, I removed this and just replaced with flexible strip. Wired directly in place of the old. Same for rear lockers, behind the driver seat locker, and the rear transom light. The only change to the wiring for the lockers was the ground wire was ran to the switch, and another ground from the switch back to the LED so when closed, the ground was interrupted and they shut off. "
    2006 Supra 24SSV
    I can't remember if there are 1 or 2 superflux in each of the factory housings in the floor. Dusty, remember?
    If you are considering doing RGB at all .... just do it up front.
    2006 Supra 24SSV
    Belton, Texas
    so KG your entire LED system is on/off by the acc switch. you have no remotes or power sources etc. just the lights and the pig tail connectors?
