Results 31 to 38 of 38
  1. #31
    Awesome work, excellent info. If your off-side sac had a check-valve in the vent line, I bet the other side fill pump would not draw air. This would reduce your fill time and improve the flow rate. yes, a larger intake setup would improve the numbers as it would offer more flow capacity. Down side is, there is a pretty good price increase when you step up from 1" to 1.25". But, a single 1.25" will be less expensive then a pair of 1"
  2. #32
    Portland Oregon
    Default Thru Hull Fitting Advice
    Thanks Chad. Been following this because I am adding a pump and two bags to my buddy's 100k boat and there's no talking him into another thru hull. He won't mind the 20% loss, he wasn't even planning on being able to run both pumps at the same time.
    -Jake
  3. #33
    Apr 2010
    saskatchewan, canada
    that is wicked that you set it up just so we all a had info on what is best for everybody's setup. 2.4 min to me is worth a hole in the boat, only bc I have two small kids and that is 2.4 min shorter that they need to wait. But for some people they may feel that it is not worth it but test is awesome and now people have legit info to make a decision on what set up is best!
    Thanks again!
    2005 Mobius LSV
    wakeplate, perfect pass,
    Fuel Injected
    1433 acme prop
  4. #34
    Quote Originally Posted by saskie99 View Post
    Thanks again!
    We have a short season, 2.4 minutes difference may not sound like much but over the entire season that's a lot of time wasted..I'd rather spend it surfing...
    2002 Moomba Mobius LSV
  5. #35
    Jul 2012
    Cumming Ga
    The one test that I meant to try out was to run one pump in the forward direction and the other in the reverse direction to see if it forced more water through the filling pump. Maybe that sounds confusing but if you have a T fitting and one pump is emptying and the other is filling then they would both be utilizing the same thru hull fitting. I would think that the pump emptying would increase the line pressure and actually feed the other pump. I am willing to bet that there wouldnt be all that much of a difference because they should be moving the same amount of water.
    I am also a little nervous about the one pump that is emptying injecting air into the system and causing the flow to go to hell. I am thinking that I'm going to go with a thru hull fitting for each pump myself. Its the air issue that I am afraid of all the way around.
  6. #36
    Where would the air be coming from?
  7. #37
    Default Re: Thru Hull Fitting Advice
    Cavitation from the pump..
  8. #38
    Jul 2012
    Cumming Ga
    Also if there is any air in the bag once it gets empty then the pump would turn into an air pump instead of a water pump and inject air into the line that the other pump is drawing from.
