So, along the same lines of cleaning the flame arrestor, do any of your guys do anything with the PCV valve? I believe in the manual, it says to either clean/check/replace (I don't have the manual right now, so can't remember which) at 100 hrs. Do any of you guys do anyhting with it? I see that it's probably a fairly cheap thing, so if you do replace it, it won't break the bank. Any thoughts?
Results 1 to 6 of 6
Thread: PCV Valve
02-23-2010, 05:51 PM #1
PCV Valve
08 LSV
Go big, or go home.
02-23-2010, 08:19 PM #2
Senior Member
- Jun 2006
- 191
I have replaced mine at about 500 hrs....they are inexspensive.
02-24-2010, 11:59 AM #3
Shake the PVC and if it rattles your good to go. If it doesnt replace it.
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
02-24-2010, 01:29 PM #4
Senior Member
- Jan 2010
- Milwaukee, Wi
- 260
I second that.Shake the PVC and if it rattles your good to go. If it doesnt replace it.08 Outback
82 American Skier
02-24-2010, 01:40 PM #5
Done and done. Thanks guys!
08 LSV
Go big, or go home.
05-01-2013, 11:29 AM #6
Is there 2 PCV valve? When I m in the boat facing the engine on the right side of the engine, near the dip stick, there is a "PCV valve?)connected to a hose that is connected just under the flame arrestor.
On the left side ( driver side) there is something that looks like the PCV valve. A hose is connected to the valve and directly to the flame arrestor.
The two valves on the right and left side look almost the same. So which one is the PCV valve?
ThanksMobius LSV 2011
