Results 1 to 10 of 17
    Jan 2013
    Nashville, TN
    Default Paint scrape on rub rail
    Got some white paint on the side rub rail the other day. Any suggestions on what to use to remove it? I used a little Goo Gone on it and removed most of it but there is still a little bit of paint on the rub rail.
    2013 Mobius LSV
    Feb 2012
    St. Albert, Alberta, Canada
    Brake cleaner.
    2010 MOOMBA LSV
    340 CAT
    ACME 1235
    3100#'s
    Quote Originally Posted by KRAK View Post
    Brake cleaner.
    That will certainly remove it, but you might want to try something less aggressive.
    What kind of paint is on the rub rail and how did it get there? I would start out using paint thinner, in a small amount rubbing it lightly.
    6 SX65M Cabins
    6 XM9 Towers
    1 XI 1K Harpoon
    2 XI 800.4
    1 XI 2500.1
    Belton, Texas
    I get paint on my rub rails quite often also. it's from the pole covers where the dealership has their logo and phone number painted on. while loading the boat the rub rails strike the markings on the covers and transfer to the run rails. I haven't found a good way to get it off. lets just say I've gone threw a boat load of magic erasers
    sent from my home phone
    2009 Moomba Mobius LSV
    Jan 2013
    Nashville, TN
    The paint was on a cushion/pad on the pole near the back of the trailer. The name of the dealership was painted on the cushion/pad. It was just white paint.
    2013 Mobius LSV
    turn the cover on the pad inside out
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Jan 2013
    North Dakota
    I don't have a good answer for removing it, but it brings up a good discussion point on preventing it in the future. My old boat has a hardened black vinyl(?) rub rail that swapped colors with my boat lift guide on rails for the days I tried putting it on sideways. The guide on rails are basically a PVC tube with a vinyl cover over it and are designed to be bumped to center the boat on the lift.
    I never found a product that would take it off and was thinking of wrapping the guide on rails in something else to prevent it all together. Are stainless steel rub rails easier to clean? What would be a better wrap for the bumpers that wouldn't swap color as easily?
    Coming soon: 2013 Mobius LSV
    For sale: 2004 Centurion T5 DD with 130 hours
    Nov 2009
    Outdoor carpet with some zipties to hold it on.
    I have used laquer thinner and it will clean the rub rail really nicely.
    -Mark
    02 Mobius LSV - GIII Ballast - Kicker 6500.2 Six Pack powered by 650.4 - Polk cabins, 10" L5 powered by Kicker 750.5 - Perfect Pass wakeboard pro
    "Hey you only live once"
    Mark, do you regularly over on this site, too?
    http://whitetrashrepairs.com/
    Simple fix is to turn the covers inside out where there isn't any printing.
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Belton, Texas
    real question here to ask wolfey is how do you know that site exists😬
