Took the boat out for the first time the other day and the wake plate wouldn't move up or down. It's acting like they might be seized up. Can someone point me in the right direction to check the fluid? It's a 04 LSV thanks!!!
Results 1 to 10 of 16
Thread: Wake plate problems
03-21-2013, 12:03 PM #1
Wake plate problems
2004 Mobius LSV
03-21-2013, 12:11 PM #2
Wake plate problems
A friend of mine had a similar issue on his Tige and it was a fluid issue. He refilled and it's been working great for a couple of years. Not sure how to check it though.
2011 Mobius LSV
Ron
03-21-2013, 02:10 PM #3
Senior Member
- Jan 2008
- Tampa, FL
- 1,361
My "blinker switch" on the steering column was mounted with the wiring very tight. By moving the wheel up and down, the wiring was pulled from the switch and caused my plate not to move. Simple fix. If you hear the pump, then you may have other issues.
2008 Outback
03-21-2013, 09:24 PM #4
03-22-2013, 06:01 AM #5
Senior Member
- Sep 2005
- Claytor Lake, VA
- 260
Pump and tank are located in the engine compartment mounted to the port (left) bulkhead support. The tank is opaque so you can see the level. If you hear the pump run but the plate doesn't move, check the fluid level. Uses ATF fluid and the fill port is very small. After adding fluid, run the plate up and down several times to bleed the air out. Also check the actuators for leaks.
2005 Mobius LSV
03-22-2013, 11:46 AM #6
Wake plate problems
Great thanks I'll check it tonight! Yea I can hear the motor trying to move but just seems to stay one one spot.
2004 Mobius LSV
03-27-2013, 07:13 PM #7
Wake plate problems
Is there any way my actuators are just electric? Cause I've looked everywhere for a place to check fluid and can't find any. Does anyone have any ideas?ImageUploadedByTapatalk1364426027.822434.jpg
2004 Mobius LSV
03-27-2013, 08:40 PM #8
03-27-2013, 08:44 PM #9
Member
- Jun 2010
- Raleigh, NC
- 47
2008 Mobius LSV, 325 Assault, Acme 1433
Ballast: 1100s rear, 400 center and IBS plumbed on valve. 3 Johnson Reversibles.
Audio: 2 SKM10 subs and 6 KM6200s powered by Kicker IX1000.5, Pair REV8s powered by JL M4300 amp, Kenwood 440u head unit, RC107 remote at helm, and RC60 remote at transom
Misc: Blue Seas Add-a-Battery, SeaDek, Evolution Cover, Blue interior LEDs, 2 Attwood Underwater LEDs
03-27-2013, 09:29 PM #10
Wake plate problems
04 LSV eventually became 08 Outback V, which I owned. Confirming that it is hydraulic and that reservoir is located in engine compartment. I believe mine was mounted on the aluminum engine box bracing, up near the ski pylon, but on the port side.
If nothing else, call a dealer or email jallen@skierschoice.comDrew
New ride: 2012 Mojo
Old ride: 2008 OBV
