Results 1 to 10 of 10
    Belton, SC
    Default WTB: Thru-hull Wire Connector 6 pin or more
    I need a connector to get my light & speaker wires from the tower into the hull. It currently has a 2 pin connector, but I have at least 6 wires I need to get thru.
    I'm open to suggestions on where to buy it from too. Thanks for any help, Ryan
    '00 Moomba Kamberra
    '99 BMW 528it
    http://www.parts-express.com/pe/show...number=092-345
    (Although I prefer the 90-degree version that holds up tight to the hull.
    http://www.parts-express.com/pe/show...number=092-347
    Oh wait - here.
    http://www.parts-express.com/pe/show...number=092-194
    Finished product:
    2001 MobiusV
    Belton, SC
    That doesn't look too waterproof? Never any problems with it?
    Any cheaper options out there y'all like?
    '00 Moomba Kamberra
    '99 BMW 528it
    Belton, SC
    I guess I should've posted this in Audio Electrical section. maybe a mod could move it for me? Thanks in advance.
    '00 Moomba Kamberra
    '99 BMW 528it
    Aug 2009
    Montana
    i used the neutrix as well but not the 90 degree version. Never a problem!
    The Neutrik connectors have been used in prosound forever and is as solid of a connector as you will find.
    If you want something more streamlined with considerably less bulk then look at the Deutsch connectors. They also have chassis mount versions and pins for up to 12-gauge.
    But if you want heavy gauge for high current, like halogens for example, in more than four poles you may have to run connectors down both sides.
    David, good point on the Deutsch connectors. I used these for my ballast mod in old boat and they worked great, even with my limited soldering skills. I believe you can buy thm pre assembled as well.
    I believe razz or newty turned me on to this site. Quick and easy to work with.
    http://www.deutschconnector.com/prod...onnectors.html
    Quote Originally Posted by rc5695 View Post
    Never a problem with water. Only problem I had was a 1am arrival at home and forgetting to disconnect it before attempting to lower the tower and park the boat. That's when I went from the straight connector to the 90.
    2001 MobiusV
    Belton, SC
    Thanks Joe. That's what I was looking for. That's what is on my boat now. I'm going to look into these this weekend.
    Berg, I'm realizing the price on what you sent isn't too bad afterall... Still in mind. thanks for the feedback!
    '00 Moomba Kamberra
    '99 BMW 528it
    Belton, SC
    ordered the same one youre running berg. thanks. hope to finish my install this weekend...
    '00 Moomba Kamberra
    '99 BMW 528it
