Page 5 of 19 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 188
Thread: Just Closed
  1. #41
    well folks the builder has officially broke ground! Heidi sent me this picture, looks like it is leveled and they have received a load of lumber!
  2. #42
    got the foundation framed in
  3. #43
    Default Re: Just Closed
    Fun times ahead! Have everything picked out?
    We are on week 3 or 4 of a renovation ourselves. Its alot of decisions!
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  4. #44
    we do but im always second guessing how it is going to look when it all comes together
  5. #45
    De Pere WI
    funny watching them build homes in the south where you just scrape off some dirt and pour a "foundation". no actual crawl space.
  6. #46
    Oct 2009
    Lockport, IL/Cloverdale, MI
    No crawl? How about no basement? Very strange to see no excavation.
    2008 Outback V
  7. #47
    Pensacola, FL
    What is a "basement"?
    "Excavate" here in Florida and you will hit water.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
  8. #48
    About the same way here in Katy. I thought it was crazy when I visited my uncle in Chicago and we hung out down in the basement.
  9. #49
    No expectation of a basement down here. Miss the storage. Attics are HOT! But we live outside a lot more so we don't need the rec space so much.
    Calgary Alta Canada
    A basement is the other half a house.... Almost. Funny we have them and its likely harder ground etc here than there yet it is very Normal for you Not to have them. Even Crawl spaces are virtually unheard of here.
    We do have other issues to deal with . Namely a frost level of Aprox 8 ft. Which then means our Plumbing services are Deeper yet so that the plumbing in the basement has somewhere to go . A few exceptions are made and Plumbing is pumped UP, but then freezing issues are quite possible.Our water supply piping is Deep to avoid the frost.
    As for square footage it usually adds nearly 1/3 to 1/2 to the size of the house depending on weather its a 2 story or Bungalow style house. Economically it makes way more sense i believe. Once basements are finished ,if done properly,can actually be warmer and or cooler than the rest of the house.
    We, i must add are in a weather cliimate, Where heat is a Must most of the year and a very sellect few will opt for Air conditioning. This i know would be a big change from most of you Warm weather folks. We honestly have but a couple weeks a summer where AC would be a real nice thing.
    Anyway to each his own and looking forward to seeing pics, hopefully of how some of the house is built etc. I'm a plumber doing new home construction, so its always interesting to see how things are done similar or different in different parts of the country..
    Good luck on your new home..... Enjoy.
    07 Outback DD
