Results 11 to 20 of 40
Thread: Oil
    Vicksburg, MI
    Rotella. I get it by the case from Sams Club.
    Joe
    2014 LSV
    2010 Outback V - Sold
    Jun 2010
    Lake Houston
    Default Re: Oil
    Rotella until 100hrs and then 20-50 Mobil 1
    2013 LSV
    2005 LSV - SOLD
    Pensacola, FL
    I like Mobil 1 oil and filters.
    If you use an oil that meets the manual standards and change it regularly, you shouldn't have an issue. IMO, the filter is the more important area on buying quality.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Jun 2010
    Lake Houston
    Default Re: Oil
    And for what its worth I use the high capacity m1-302 filter from mobile 1.
    2013 LSV
    2005 LSV - SOLD
    Sep 2005
    Claytor Lake, VA
    Posted this yesterday but must have gotten lost in the server restore.
    From the 05 manual:
    Engine Oil
    The engine crankcase oil should be selected to deliver the
    highest performance for your operating conditions and
    climate. In general engine oils with lower viscosity ratings
    are used when outdoor temperature remains low. Oils with
    higher viscosity are used when outdoor temperature is
    warmer and when higher performance is expected from the
    engine.
    Indmar recommends 15W-40 Pennzoil Marine in their
    engines. If not available, use a 15W40 motor oil with an
    A.P.I. classification rating of SL/SJ/CI4/CH4/CG4 or
    equivilent. Synthetic oils are not recommended until after
    the engine has been run for 100 hours.
    2005 Mobius LSV
    Sep 2012
    Chattanooga, TN
    Rotella T for me.
    2005 Moomba Mobius LSV
    Oct 2008
    Central, Arkansas
    +1, Rotella T w/ WIX 51060. I am not sure how the taller filter will do directly on the motor as to a remote location.
    Default Oil
    What's the difference in this and the m1-111?
    Sent from my iPhone
    2015 Supra SG
    Jun 2010
    Lake Houston
    Default Re: Oil
    Sent from my iPhone
    Its double the length.
    2013 LSV
    2005 LSV - SOLD
