Results 21 to 30 of 40
Thread: Oil
    May 2012
    Memphis, TN
    15w-40 Pennzoil Marine oil as the manual states....
    2011 Supra 21V
    2012 Tundra SR5 Crewmax
    Wetsounds Icon8's
    Jun 2010
    Lake Houston
    Default Re: Oil
    Quote Originally Posted by blackout_58 View Post
    Where do you even get that at? I searched all over creation.
    2013 LSV
    2005 LSV - SOLD
    Vicksburg, MI
    Default Re: Oil
    West Marine carries the Penzoil.
    Joe
    2014 LSV
    2010 Outback V - Sold
  4. #24
    Oct 2008
    Central, Arkansas
    My local Ace Hardware used to order it in for me... but now they cant. Changed to rotella.
  5. #25
    Oct 2005
    Durham, NC
    I'm with blackout, I use the Penzoil Marine 15W40 just like the manual says. I have to get it at the local Mastercraft dealer. I use the Penzoil PZ3 (or PZ52 or whatever it is now) oil filter as well.
    Brian Roberts
    2001 Outback DD
  6. #26
    Aug 2008
    Cottage Grove, MN
    Default Oil
    191
    Lol!.......
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  7. #27
    Aug 2009
    Montana
    Default Oil
    I use the same. Bakes marine online carries it and usually has a fall or spring discount that I capitalize on. Also pick up my impeller at the same time.
    2015 "NOT A MOOMBA"
  8. #28
    Apr 2013
    Spokane WA
    Mobile Delvac 1300 Super 15-40
    2012 Mojo
  9. #29
    Mar 2012
    Stevens Point, WI
    Valvoline VR1 racing oil. 20w-50. Non-synthetic.
    Kevin
    1993 Supra Sunsport
    5.8 351 HO PCM @ 285hp
    PCM (40 A) 1.23:1
    Acme 422 Propeller 4 Blade 12.5 X 15.5 RH 1" Bore .105 cup
    Ballast: (2) 540 lb and (2) 350 lb Straight Line Launch Pad
    Wakeboard: '11 CWB Absolute w/ Faction bindings
    Surfboard: '08 Hyperlite Broadcast
  10. #30
    Apr 2013
    Spokane WA
    Called Indmar today to discuss oil. Told the gentlemen I spoke with that I had a 2012 Mojo with the 345 Assault motor and was hoping to get a few alternatives to the recommended Penzoil product. We specifically discussed the following oils as suitable alternatives:
    Rotella 15-40
    Delo 15-40 (non LE)
    Delvac Super 1300 15W-40
    Hope this helps those of you searching for options to the "hard to find" Penzoil Marine product.
    2012 Mojo
