Results 1 to 9 of 9
Thread: Need help
    Mar 2013
    Default Need help
    Iam new to this kind of boat(2006 outback my first direct drive) can someone please explain how to grease my rudder and steering cable,and also what are some pros and cons of my prop 13x11.5 acme 3 blade.What kind of rpm range to stay in and top speeds for this setup,Thanks
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    Jun 2010
    Lake Houston
    Default Re: Need help
    Your steering cable cannot be lubricated. However some will chime in here and talk about drilling holes in the tube and jury rigging a way to lubricate it. The rudder has a grease fitting on the inside of the boat where it comes through the hull.
    2013 LSV
    2005 LSV - SOLD
    Mar 2013
    So does that mean I have to take up the floor between the engine cover and rear seat to access the fitting
    2013 LSV
    Tuscaloosa, Alabama
    You can open up the Gull Wings in back and unscrew the floor out in there and then you will see the grease fitting through the gas tank. Doesn't really take long at all!
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Mar 2013
    Quote Originally Posted by jmb View Post
    Great sounds better than opening up the floor
    2013 LSV
    Calgary Alta Canada
    Opening up the floor is really quite simple as well ,just 4 screws hidden in the carpet , behind the motor clamshell.
    07 Outback DD
    Calgary Alta Canada
    You can take the floor out to change trans fluid and check dripless/ non dripless water seals and mufflers etc all at the same time as well....
    07 Outback DD
    Definitely worth learning how to take up the floor. Should be giving everything under there at least an annual inspection anyway.
    Aug 2009
    Montana
    hardest part about taking up the floor is finding the screws hiding out in the carpet
