Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    Default Oversized speaker suggestions - ??
    I knew this would come again so here we go. My cutouts for the cabin speakers are 6" holes. Running 6.5" speakers has been a bit tricky to mount. I basically had to have another ring under the back side of the hull and 'clamp' the speakers to the hull with mounting screws.
    Been looking around a little and so far the closest option is the JL7.7's needing an opening size of 6.25" - I could probably make that work.
    Anyone know of any other larger sizes that take around 6" opening? The less cutting or fabricating of adapters the better.
    Oct 2008
    Central, Arkansas
    Would installing speaker LED's help.
    HA! I thought the same thing.
    Know anybody selling them?
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    That may work. I would need them to be ~ 5" inner diameter, and at least 6.5" or however large to match the grill size outer diameter.
    Feb 2013
    Norcross, GA & Lake Lanier
    When I'm here. You got them covered HAHA
    Kicker KS65 requires a 5-5/8 hole but do not know the OD of the grill or the bolt spread
    Kicker CS67 requires a 5-1/2 hole but do not know the OD of the grill or the bolt spread
    If you stay with a smaller speaker, even adding an LED ring you will be left with a similar issue. The 6" cutout will leave you a very narrow window of hull for the screws to go through. Centering the speaker to drill the pilot holes is critical. Depending on the thickness of the hull, I would still consider using a backing plate with ID and OD thats the same as the speaker and bond it to the back side. Another option would be to use machine screws with washers and nylock nuts as opposed to screws. The washer distributes the load and the machine screw and nut allow for a little tighter torque.
    Another option would be to have a piece of deck colored HDPE milled out so the speaker fits through it snug and it fits into the 6" cutout and has an overlapping lip with an OD that matches the speaker. .25" would only set the speaker out a little from the deck, so it would not be too noticeable.
    If you are up to the expense of new and larger speakers, then problem solved. Just open the existing holes up to match the cutout of the new speakers.
    Feb 2013
    You can easily fit exile 65m In 6" hole without any issue because I just did that. Hole diameter is around 6.7 and speaker including grill around 7
    Feb 2013
    Quote Originally Posted by sgoyal View Post
    I just measured Exile SX65M... Hole starts close to 6 1/4" and full OD is around 6.9-7"... their inside diameter is 5.11
    All of Kickers marine in-boats are right at 7" OD, so are the Wet Sounds 650 and 65 series. The Rockford M626 is also 7", but the JL M650 (6.575) and the Alpine M600 (6.65) are both on the small size and the polk comes in @ 6.755.
    Feb 2013
    I agree. JLM650 is the only one that is smaller than all. Most of the 6.5 inch speakers are 7" OD..
