Results 1 to 10 of 10
    Nov 2009
    Nebraska
    Default Rear ballast bag connection
    Filling up for surfing and my ballast came loose spilling water everywhere. Notice that the quick connect elbow that a piece was busted off. So I need one of these
    http://www.wakemakers.com/fly-high-p...ting-w746.html
    Now I noticed to install that I need this
    http://www.wakemakers.com/pinch-hose-clamp.html
    My question is what size will I need and do I really need the tool
    2010 Moomba LSV
    Feb 2010
    Canton, Ga / Lake Lanier
    Why don't you just get a hoseclamp from Lowes? I just did my hole project with those. Sure the crimp ones look nicer but are a PITA to remove if you ever need to.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Saugus, Mass
    I second the hose clamps. Quick and easy to disconnect for whatever reason later.
    Default Re: Rear ballast bag connection
    Zip ties.. Easier..
    2006 Moomba Mobius LSV
    Lake Amistad, TX
    Is this a common problem!?!? I just installed 2 1100lb bags in the back and I didn't even think about something like that happening... that would not be fun!!
    2008 LSV Blue on White
    Nov 2009
    Nebraska
    Mine happens every once in a while, I also noticed the back panel of the ballast location has had two screws loose, don't no if this was causing it
    2010 Moomba LSV
    Nov 2009
    Nebraska
    Like this one
    http://www.wakemakers.com/stainless-hose-clamp.html
    2010 Moomba LSV
    Feb 2010
    Quote Originally Posted by snyderaaron View Post
    Yep...that exact one. I think I paid $4.99 for a pack of 10.
    Tow Rig:
    Second lowes or Home Depot for the the ss clamps, bought lst of them for my upgrades, use black electrical tape around the bags.
    fittings try this
    https://www.flow-rite.com/product/ma-049
    Sep 2005
    Claytor Lake, VA
    I used the pinch clamps around the bags and regular hose clamps everywhere else. Old end nippers make a good tool for pinch clamps. I like the zip tie idea.
    2005 Mobius LSV
