    Sep 2009
    Langdon ND
    Unhappy Trailer springs?
    By the looks of pictures the trailers look to be going back to the springs. I sure like the torsion set up, probably to save costs?
    Quote Originally Posted by gmg View Post
    The torsion is an option now or has always been. I have springs on the Mojo.
    I had torsions on the LSV.
    So fare i really prefer the springs on my Mojo, the trailer bounces a lot less, the tires are flexing less and the boat just seems to pull much easier, less jerking.
    Down side is the trailer sits higher, and it squeeks more when your going slow.
    Default Trailer springs?
    Ha! I think this is Moombadaze's only complaint with his new LSV and he lives 3 min from the ramp! Says it drives him nuts.
    Torsion are an option as Mike said.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Lucky i only hear then when backing down the ramp, I might try some WD40 on the end bolts, see if it helps but other wise I do like them. I actually thought they were the upgrade till i looked it up because the boat rides so much smoother. It actually acts like it has a suspension LOL.
    Long term, i cant say id i will still like them or not.
    I never had an issue with the torsions and other then the bouncing over the bumps i never noticed them.
    Give it a few years and they won't squeak anymore I betcha. Only time I get a squeek out of my old schooler is when I go over speed bumps.
    Traverse City, MI
    Mine hasn't started squeeking at all - knock on wood! I do find it a little annoying that the leafs are lime green, instead of black but that's easy enough to fix.
    Mine are grey to match the trailer as well, i think they spray the trailer fully assembled just with no wheels.
    Oct 2005
    Durham, NC
    Wow, I didn't know that the torsion axles were an option. What are the pros and cons of both setups? With all the torsion axles failure that seem to happen, one would think mire folks would choose leaf springs.
    Brian Roberts
    2001 Outback DD
    Sep 2009
    Langdon ND
    On our rough roads up here in ND the torsions are a way better option I feal as the boat doesnt bounce around as bad. I have had a sprung leaf spring on our old boat trailer and you could actually see the wheal leave the pavement quite a bit with the leafs and not with the torsions.
    in 08, torsions were standard, now there optional to help keep cost down
