Results 1 to 9 of 9
    Default Speed cluster problem (help)
    My speedometer doesn't want to hold his speed. The arrow is always moving from 0 to the end of the cluster. Sometimes it stays on the speed for about 20-30 sec before going crazy again. Is there anything I can do about it before going to the dealer ($$) ?
    I know I can take off the cluster under the steering wheel but just want to know before if this is a frequent problem.
    Thank you
    Boat is an moomba LSV 09
    check the paddlewheel underneath first for any damage, then check wire connections on the inside at both the paddlewheel and all the way to the speedo. You can replace the paddlewheel assembly on your own for not too much $$ (if I remember correctly, Mike Mandley and/or Ian did this) before taking it to the dealer.
    2015 Supra SG
    Irondequoit Bay, NY
    mine doesnt work haha..but on my outback its to easy to get to..i might replace the wheel assembly
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Feb 2011
    Has anyone heard that excessive trailering can cause the paddle wheel to spin too fast thus messing up sensors. Mine was doing the same thing that you describe but no visible damage. Boat mechanic told me as much as I trailer I should put the blank in while trailering.
    Bought a new paddle wheel on eBay 39.00 i think and fixed problem
    yes, I have heard that can happen but it might have been on here, so who knows if it's true, or not.
    2015 Supra SG
    Irondequoit Bay, NY
    huh..never thought about that
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Ok thank you i'll check on it
    anyone have a link for a paddle wheel?
    and let you know guys if not i'll look at the connections and the cluster
    at least it's not the cluster
    Default Re: Speed cluster problem (help)
    Paddle wheel is fine
    Connector was ok
    I'm trying this we everything if not it's the cluster
    Sent from my SGH-I747M using Tapatalk 2
    Update *****
    Didnt found out the problem yet
    Paddlewheel is ok and make move the speedometer
    Connections are good on the cluster
    I dont know what to do (could it be the cluster or the speed calibration)
