Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    May 2013
    Default first time surfing
    looking for a little advice on surfing with a 2012 mojo with factory ballast (2 450lb bags in the back lockers, and the hard tank). So my previous boat was on I/O so we have never surfed before. my main thing i want to know is if the boat is surf-able with just the factory ballast? just keep in mind that i am not looking for the best wave ever, just something to learn and have fun on at first.
    thanks
    2012 Moomba Mojo
    Jul 2009
    Cleveland, Tn
    Get bigger bags
    But seriously, if u can't get new bags at the moment u could fill and then cap off the first bag then hook up the second bag and fill it in the same locker.
    Best bet is either to get bigger bags or lots of people to use as ballast!
    2012 Mojo
    2009 LS (SOLD!!!)
    2010 Tundra 5.7 Crewmax 4X4
    May 2013
    Quote Originally Posted by Salyers View Post
    Get bigger bags
    are you recommending i just get bigger bags for the back? would 750's work? i would like to keep so room back there for storage.
    2012 Moomba Mojo
    May 2013
    maybe i could just use my sister as a ballast system
    2012 Moomba Mojo
    Feb 2010
    Canton, Ga / Lake Lanier
    You should get 1100s and an IBS. Lots of info on here regarding weighting a Mojo. Look for post by Wolfeman and mmandley. I think most run 1100s in rear 400s under side seats, Center tank/bag and an IBS. That is also what I run in my LSV.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Apr 2013
    Thoughts on an 09 Outback V ballast for surfing. I have the Gravity III system currently, I saw some 750lb bags at my local sports store today for $150. Would it be as easy as unplugging my current bags and plugging the new ones in? Not sure if there is a standard on the fill connection?
    Apr 2012
    Quebec, Canada
    I don t know for the Mojo but with the lsv yes you can surf with only the stock ballast but the wake as not a lot of push so it is harder for a beginner because you really have to stay in the sweet spot and this spot is not long. for me bigger bags= easier and much more fun. I run the same bags as E4Nash in my Lsv and the wave is a lot longer and has a lot of push.......so you don t have to fight to stay on the wave....
    Mobius LSV 2011
    This is the way to go with a Mojo. You'll get frustrated trying with just the stock bags. At a minimum, you need the 1,100 for the surf side.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Quote Originally Posted by TuxRaptor View Post
    Buy them & you'll be happy. Might be plug & play, but there are 3/4" and 1" fittings out there. I think your boat has 3/4", but if those bags have 1", you can order new ones from wakemakers.com and swap them out.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    May 2013
    Do I need to support the wall next to the engine compartment with the 1100's in there? And if so how?
    2012 Moomba Mojo
Tags for this Thread
