Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Mar 2012
    Uniontown, oh
    Default Water leak thru prop shaft
    I'm getting a steady trickle of water comming between the prob shaft and brass fitting before the hose clamps. Is there a seal that can go bad? What's the fix like? It's enough of a leak to kick the bilge on after a while.
    Nick
    2005 Moomba outback
    Pensacola, FL
    Based on your options: you can re-pack the seal in there. It's fairly easy after you remove the cowling and the rear panel. You could just tighten up the adjusting nuts and see if that reduces/stops your leak. Lastly, you could convert it to a dripless.
    While I have been able to repack them and have no leak at all, the manual states that is will leak a few drops per minute.
    When I flew the Navy's E-6B, the engines were "allowed" to leak "up to" 30 drops per minute and still be "good". I only saw them leak once and it was in a "greater than 30" flow.
    In helicopters: if it ain't leaking, it must be out of fluid.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Irondequoit Bay, NY
    any cons to a dripless? i think i might pick up a dripless drive seal
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Jul 2012
    Cumming Ga
    Yea there is a draw back with having a dripless shaft seal. I personally had to change mine because they wear out just like any other seal. They are more complicated and in my opinion unnecessary. The biggest issue is when they go, they go. So you could be on the lake and fill up pretty quick with water with no way to empty it out. With the rope type seal you can generally tighten the nut a little in case of an emergency.
    Also the dripless still drips. Well at least mine does. So if you want a totally dry bilge your out o luck either way.
    Quote Originally Posted by Ironcross25 View Post
    It's supposed to drip a little, that's what keeps the packing rope lubricated. After a while, the rope needs to be replaced. Below is the replacement procedure. It's not hard and is much cheaper than going dripless.
    http://www.moomba.com/msgboard/showt...+seal+cab13367
    How many hours do you think you got out of it before having to change it?
    2001 MobiusV
    The dripless does not drip if its installed correctly and your alignment is within tolerances. So yes , why not have a dry bilge?
    Jul 2012
    Cumming Ga
    The boat has about 550 hours on it and I would assume that the shaft seal has never been changed before. That is a long time and I understand that its a wear item but the worst part for me was the fact that it really went all at once. I noticed that my bilge was running a lot so I just happened to take a look and there was a lot of water in there and the shaft seal was dumping in a steady stream of water.
    I had Atlanta marine install the new seal but it still leaks a little. I noticed it dripping the other day a little. I would also expect it to hold up to the name of "dripless" but it still leaks. I drive from Atlanta to the SC factory to pick it up so its a factory part literally. I just don't feel like paying another 750+ dollars to have it replaced again.
    If I were to order a new boat from the factory I would not buy a dripless seal is all I'm getting at. Everyone has their own opinion on the issue but mine is keep it simple, who cares if you have a little water in the bilge. More then likely you will have a little water in there from people getting in and out of the boat, from life jackets and wet suits holding water, and from the rain that makes it through the cover.
    Jul 2012
    Cumming Ga
    I would think that they got it aligned correctly but I really have no way of telling. That's why I paid a ton for them to do it but who knows what they actually did. I personally don't have any feeler gauges to check alignment, maybe I should buy some and take the bolts out to see what it looks like. It may be off. I don't want to totally crap on the dripless idea, and I know a lot of boats have them, even really big boats. I just had a bad experience, I like the idea of just tightening a nut a half turn every few years and knowing I'm good to go. Also if it fails I like not having to tare off the V-Drive and all that stuff. Dripless is just really easy.
    this really costs $750 bucks to get done???? i had a motor mount replaced for cheaper than that!!
