    Muskoka, Ontario
    Default Cleaning threads of block drain ports and transmissions drain plugs
    After putting back the plugs on the block and transmission from winterization I noticed they were heavily crusted with rust and had a hard time threading them back in. I was able to clean them enough to get the plugs back in but they don't go in very deep and didn't want to reef on them hard in case they were going to ruin the threads.
    What do you guys do to clean the threads? Do you use an SAE tap and re tap them carefully to clean out the rust etc?
    Vicksburg, MI
    Default Re: Cleaning threads of block drain ports and transmissions drain plugs
    Run a tapered pipe tap in the hole. Do not cut the treads deeper, just clean them. Next fall, coat the threads with grease or vasoline to keep the rust off.
    Joe
    2014 LSV
    2010 Outback V - Sold
    Pensacola, FL
    The store sells thread taps and thread cleaners. You want a cleaner, they look very similar. Use it to clean out the threads and put grease or vasoline on the thread cleaner to keep the stuff in the goop and not in the head.
    Anti-sieze the plug threads to help prevent corrosion.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Pb blaster next time you pull them out..
    2006 Moomba Mobius LSV
    Muskoka, Ontario
    Anyone know off the top of their head what size it is? 1/4" NPT?
    Vicksburg, MI
    If you use a 9/16" wrench to take the plug out, which I believe is true, then yes it is 1/4" NPT.
    Joe
    2014 LSV
    Mar 2008
    I would coat the threads both the plug and the hole w/ never-seize after you clean the threads.
    Sent from my iPhone 5... ya right!
    PWI as usual...
    Why do you leave them out all winter? I take mine out, and after it drains I put them back in
    Sent from my iPhone
    Muskoka, Ontario
    Sent from my iPhone
    I didn't, dealer took out all the plugs and left them in the cup holder all winter. I only noticed when I went to go summerize the boat this year.
    Quote Originally Posted by loudsubz View Post
    That way they can justify a paltry to exorbitant summarization charge.
