    Default Depth finder 09 lsv
    Quick question. How does the depth finder determine the depth because it said 2.5 ft and I know I'm in at least 4-5 foot of water, is that from the bottom of the boat or how does it come to that?
    Sent from my SCH-I545 using Tapatalk 2
    2009 moomba Mobius lsv
    Jul 2011
    Murrieta, CA
    It should read the depth from the transducer mount location. Most units have a calibration feature if the reading is not what you want.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Quote Originally Posted by kregstrong View Post
    Its prolly reading from the bottom of the Prop.
    I know i adjust mine to read from the bottom of my prop because the prop will hit the ground before my boat LOL.
    Nov 2009
    Gatineau, Quebec
    Sorry to hijack but what if it only reads this. ( -- ) its my 2012 , is the sensor no good or does something need to be done to get it to work
    2012 Mobius LSV
    05 Outback LS SOLD
    Quote Originally Posted by papou View Post
    Generally it reads that when you are in water more then 200ft. It will do that sometimes when you have a lot of turbulance under the boat.
    If it reads that all the time it isnt working correctly.
    Irondequoit Bay, NY
    someone cut the wires to mine haha
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Nov 2009
    Gatineau, Quebec
    Ok well im going to check all the conection and see if the sensor is still glued to the bottom of the boat .
    2012 Mobius LSV
    05 Outback LS SOLD
