Results 1 to 10 of 12
    May 2013
    Default Refilling v-drive oil???
    This could very well be a nonsense question but heard from a neighbor today that when you go to refill your v-drive oil it might need to be refilled from the bottom? I wanted to check and make sure before I tore into it. Thanks
    Vicksburg, MI
    Default Re: Refilling v-drive oil???
    No. You refill thru the breather on top. The breather is removed with a wrench. Remove the dipstick so that it will vent when filling.
    Joe
    2014 LSV
    2010 Outback V - Sold
    May 2013
    I just used the dipstick hole.
    May 2013
    Thanks I figured as much you would fill through the dipstick hole or that breather but wanted to sure I appreciate it
    Vicksburg, MI
    I use the vent because it is a larger hole. A small funnel fits nicely.
    Joe
    2014 LSV
    Apr 2012
    Wake Forest, NC
    I fill through the dipstick hole with a small funnel and a rag around the base to catch what doesn't go down
    2008 Outback V
    I just hold the bottle about 2 feet above the dipstick hole and pour it perfectly down through the hole without spilling a drop.
    Oct 2008
    Central, Arkansas
    hummm... that sounds like a "hold my beer and watch this" moment
    Jan 2011
    Western PA
    Turkey baster works to refill as well thru dipstick hole.
    Aug 2010
    Acworth, GA
    Sounds like your neighbor is thinking about a Mercury Alpha leg, which is filled from the bottom.
    Kraig - 2010 Outback V
