Results 11 to 20 of 25
    Feb 2013
    Norcross, GA & Lake Lanier
    Default Re: Preparing to do battle with drain plug light
    Is this just one light?or you had others too?
    Samsung S4...
    Quote Originally Posted by sgoyal View Post
    Samsung S4...
    This is just the one drain plug light. The photos are taken standing on the sun pad. The clearance to the wake plate is the biggest issue as the bulb is so big. It appears as tho it just cleared on my boat But my wake plate moves very little between down an up and I'm not sure if it is ok in the up position. Wake plate mounting is the key issue here
    99 Outback LS. Sold
    Feb 2013
    Looks like the smaller Drain Plug might be solution for wake plate issue.
    Samsung S4...
    Samsung S4...
    If you mean a drain plug extension .... No that will make it worse as the bulb will extend further out The best would be a faux drain plug you could mount above the drain plug to screw this into and only have to drill a hole for the power wire. That would be choice
    99 Outback LS. Sold
    Feb 2013
    No I meant to say that smaller Drain Plug Light. . Look at the pix I posted. .
    Gotta work with Drew I guess haha
    Samsung S4...
    Feb 2013
    I really liked the pix. .I have SeaDoo and can put 2 lights. . I put one to test it but never got a chance to go out at night. .
    I'm wondering if I put 2 of those behind my boat. .. it's gonna look freaking awesome
    Samsung S4...
    Mar 2008
    Huh huh...You Canadians spell "center" funny.
    PWI as usual...
    Samsung S4...
    put those side by side with a tape measure ..
    Feb 2013
    I'll do that later today. . summer camps are going on. .. kids are keeping me busy today
    Samsung S4...
    that look to be a much "slimmer" light housing and may work as the other was very close, but I couldn't get it aligned with the drain plug threads as the outer housing hit the hinge.
    Doc, I didn't have anyone in the boat to assist either and was sitting attempting this while sitting on a float in the water. I don't think the angle of the plate was my issue with installation though.
    2015 Supra SG
